1987 kawasaki 454 won't go over 55 mph or 5000 rpm
- lifesvr1018
04 Jul 2012 17:23 #533855
by lifesvr1018
1987 kawasaki 454 won't go over 55 mph or 5000 rpm was created by lifesvr1018
I recently had carb cleaned by mechanic and now kawasaki 454 will not exceed 55 mph.
- faffi
- Thank you received: 36
04 Jul 2012 18:58 #533865
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Replied by faffi on topic 1987 kawasaki 454 won't go over 55 mph or 5000 rpm
Could be several things. If the ignition advance is mechanical it can have become stuck, although not the most likely cause here. More likely, your mechanic made a mistake of some sort, like rupturing a carb diaphragm.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- lifesvr1018
05 Jul 2012 00:01 #533922
by lifesvr1018
Replied by lifesvr1018 on topic 1987 kawasaki 454 won't go over 55 mph or 5000 rpm
I will take a look at the carb diaphragm. Is there anything in particular I need to look for?
- MFolks
- Thank you received: 540
05 Jul 2012 00:03 #533923
by MFolks
Replied by MFolks on topic 1987 kawasaki 454 won't go over 55 mph or 5000 rpm
Any tears,or holes are signs of air/fuel delivery problems.
The following user(s) said Thank You: lifesvr1018
- tinlizzie37
- Thank you received: 1
05 Jul 2012 15:32 #534045
by tinlizzie37
Bob KZ 650 E1, En 450
Replied by tinlizzie37 on topic 1987 kawasaki 454 won't go over 55 mph or 5000 rpm
The EN 450 has to have the filter rubbers hooked up or it runs too lean. The advance is electronic on these bikes. Do check for air leaks and hook up carbs with stock air filters. Sounds like your too lean. Bob
- baldy110
- Thank you received: 512
05 Jul 2012 17:13 #534067
by baldy110
Replied by baldy110 on topic 1987 kawasaki 454 won't go over 55 mph or 5000 rpm
Did it go faster than 55 prior to the carb cleaning?
- lifesvr1018
06 Jul 2012 23:07 #534367
by lifesvr1018
Yes, the bike went well over 70. The mechanic cleaned the carbs and installed a new petcock I had ordered. Now will not go over 5000 rpm.
