still noise after starter clutch rebuild
- mrbell83
03 Jul 2012 15:37 #533625
by mrbell83
still noise after starter clutch rebuild was created by mrbell83
i own a 81 kz650,after rattling noise began when trying to start engine i looked for info, and found many postings saying problem was probably the starter clutch. bought parts and replaced springs,push rods, and rollers,but after getting engine back together noise was same as before. are there other things which could be going wrong either with the clutch or otherwise which could be causing these noises.
- Thank you received: 2829
04 Jul 2012 16:39 #533849
by 650ed
Replied by 650ed on topic still noise after starter clutch rebuild
Oooops - did you forget to replace the starter clutch sprocket? Ed
