- Thank you received: 1
charging system on a kz750ltd h1
- zig
02 Jul 2012 19:06 #533441
by zig
charging system on a kz750ltd h1 was created by zig
ok i bought a used stator and rectifier for charing for my bike it all worked fine so now its not charging bat agian i bought a new bat from advance auto it worked fine but now low on fuild what else can i do with this bike getting real pssed about this lol
- MFolks
- Thank you received: 540
02 Jul 2012 19:21 #533443
by MFolks
Replied by MFolks on topic charging system on a kz750ltd h1
Download,and read the PDF file on troubleshooting charging systems: .
www.electrosport.com/technical-resources.../fault-finding-guide
If your bike is putting out more than 14.5 volts at idle, the battery may be being overcharged, boiling out the fluid.
- Motor Head
- Thank you received: 391
02 Jul 2012 21:24 #533455
by Motor Head
Replied by Motor Head on topic charging system on a kz750ltd h1
What is the used Regulator/ Rectifier, a 5 or 6 wire? If 6 what do you have the Brown wire hooked up to? If the 5, have you checked the voltage across the battery when running at 4K RPM?
- zig
02 Jul 2012 22:24 #533476
by zig
Replied by zig on topic charging system on a kz750ltd h1
its a 5 wire with the wht / red one by its self ow do i test mag and what do i look for on it
- zig
02 Jul 2012 22:26 #533478
by zig
yes i checked it with volt meter and it goes up to 11.7 grrr
- Motor Head
02 Jul 2012 22:31 #533481
by Motor Head
What does the 2 yellow wires from the Stator put out in AC volts?
- zig
02 Jul 2012 23:23 #533491
by zig
i have 3 yellows its dark out now lol i cant see nothing what should the out put be and how i check it what they say to use on that link to test i dont have that on mine grrr
- Motor Head
03 Jul 2012 00:19 #533505
by Motor Head
3 Yellow, ok thats the 3 phase. Any 2 of the three, should put out 56 ACV. This is at 4K RPM in the book, but you will get it at 1800 or so. If you have a really good OHM meter you can check the resistance , same any two of the three, should be.7 ohm.
- zig
03 Jul 2012 20:59 #533693
by zig
i think i got it its pushing 12.8 at 4500 rpm at idale its at around 12.3 to 12 freaken stator wires got mangled some how now #2 carb pissing gas out of over flow grrr i think jet came lose again where that plastic cap is can i use something else instead of that plastic cap
- zig
03 Jul 2012 21:05 #533696
by zig
if anybody got a set of carbs lying around for kz750ltd ill buy them from you
- Motor Head
03 Jul 2012 21:08 #533698
by Motor Head
It should be 14v @ 4K RPM. You still have an issue, bad connection or 1 side of the 3 phase stator, hence the check for ACV on each 2 pair combo of the 3 yellows.
they sell new plastic Pilot Jet plugs, but I've see a post where someone found something else that fit. Maybe a search on Pilot Jet plug Plastic would get it.
- zig
04 Jul 2012 21:00 #533889
by zig
ok went though whole charging system today ya i know its the 4th but i wanted to ride my bike i got up at 4:30 am lol started working on it at 5 30 lol brang coffee maker out side wife wasnt to happy lol but i got it charing i used coco cola it had bat acid in conntctions found yesterday that stator wires wher chewed up so i temp fixed them last night lol well today i made all new wires using same color code took a long time to find all my wires im a pack rat i take every thing and anything lolso about 430pm i finished it up fixed #2 carb it was the needle but number 4 still giving me probblems pours out of over flow when i stop so i ored carb kit from jc whitny for 25.00 with free shipping until july 5th thats a deao on any thing you order so i got to ride today it was great even though i smell like gas grrr but ill take back apart and redo every thing agian thhanks for all the advise you all gave me got to love this form
