question on MAC exhaust
- kz750ohio
02 Jul 2012 13:12 - 02 Jul 2012 13:13 #533353
by kz750ohio
1982 kawasaki kz750 with mikuni carbs bs34, stock everything else.
question on MAC exhaust was created by kz750ohio
I finished the installation of the MAC 4 into 2 exhaust on the old girl. I followed the advise of re-jetting the carbs because she was running lean. The jetting has been a long process because I have been going up one size at a time. The question I have is it normal for MAC exhaust systems to be loud and is it normal to go up so much on the jet sizing. Also I had to go up a lot on the main jets in order for the mixture not to be lean. The carbs are Mikuni BS34. They started out at 117.5 mains and 37.5 pilots. Needles are not adjustable. Currently I am at 142.5 mains and 40 pilots. If I go smaller on the mains I get the copper color on the pipes. The plugs are still somewhat white but the next size jet is 145 which is the largest available from mikuni.
Am I doing something wrong or is this normal. Also forgot to mention I bought the exhaust off of ebay used.
Thanks,
Max
Thanks,
Max
Last edit: 02 Jul 2012 13:13 by kz750ohio. Reason: update
- bountyhunter
- Thank you received: 337
02 Jul 2012 16:11 - 02 Jul 2012 16:12 #533395
by bountyhunter
Are you running stock air box or pod filters?
Replied by bountyhunter on topic question on MAC exhaust
No to both questions. Sounds like somebody screwed with the baffle?kz750ohio wrote: The question I have is it normal for MAC exhaust systems to be loud and is it normal to go up so much on the jet sizing.
Last edit: 02 Jul 2012 16:12 by bountyhunter.
- kz750ohio
02 Jul 2012 18:57 #533438
by kz750ohio
Replied by kz750ohio on topic question on MAC exhaust
I am running stock air box.
- bountyhunter
02 Jul 2012 20:12 #533446
by bountyhunter
maybe the PO drilled the baffle into a straight pipe?
- Polar_Bus
- Thank you received: 7
03 Jul 2012 09:20 - 03 Jul 2012 09:21 #533546
by Polar_Bus
Bikes:
'84 GPz1100
'06 HD Fatboy
Replied by Polar_Bus on topic question on MAC exhaust
Seems like you are making totally unnecessary richer main jet swaps based on the fact you still have the stock airbox. I'm thinking you have a fuel flow issue, or possibly and air leak (intake boots). My GS1100 had a nice free flowing custom built by me 4-1 MAC with a D&D muffler (stock airbox) and all's I had to do was bump the pilot jets one size richer, and add a .020" shim under the needles.
Bikes:
'84 GPz1100
'06 HD Fatboy
Last edit: 03 Jul 2012 09:21 by Polar_Bus.
- loudhvx
- Thank you received: 1616
03 Jul 2012 10:10 #533555
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic question on MAC exhaust
The 4-into-1 Mac exhaust (bought new) on my 550 was much louder than stock, and definitely required significant up-jetting.
With stock aribox and filter:
The pilots went up from 32 to 37.
The main went from 94 to 99, but I put in a richer set of needles. Without the richer needles, I would have been near 102 to 106 on the mains probably.
I don't know if the 4-into-2 uses the same muffler baffle as the 4-into-1, but my baffles were just two pipes welded together. I ended up crushing the pipes slightly to give a little more restriction and make it slightly quieter. I still don't care for the sound, so a Kerker canister is probably going on it in the near future.
1981 KZ550 D1 gpz.
Other links.
- kz750ohio
03 Jul 2012 10:41 #533563
by kz750ohio
I will look into the fuel flow and make sure she is not being held back. I have the stock petcock (vacuum type)on the tank. This weekend I will put the tank and look at the petcock and make sure the screens are not being blocked and see what kind of flow I get out of them. I will also change the inline filter to be safe. Its about a year old.
thanks for all the wonderful idea's.
max
max
- loudhvx
03 Jul 2012 10:52 #533565
by loudhvx
1981 KZ550 D1 gpz.
Other links.
MAke sure it's not a paper, inline car filter. Those tend to stop flowing. There is not enough pressure from gravity compared to a fuel pump, so they just sort of seal off after a while.
1981 KZ550 D1 gpz.
Other links.
- Motor Head
- Thank you received: 391
03 Jul 2012 10:52 #533566
by Motor Head
Replied by Motor Head on topic question on MAC exhaust
If you haven't done so, I would do five things. Make sure your carbs don't have a blocked screen above the Needle and seat assy. Then use the Clear Tube Gauge for setting the Fuel level in the bowls.
Check for vacuum leaks around your carb holders/ intake manifolds. Make sure the diaphragms are not leaking, either holes or sealing at the caps. Make sure you Ignition advancer is moving freely with correct timing, and coil voltage is within .5v of battery voltage. I guess thats 6.
A valve adjustment is always a good idea, if you haven't recently. 7
- Polar_Bus
03 Jul 2012 15:35 #533623
by Polar_Bus
Bikes:
'84 GPz1100
'06 HD Fatboy
Have a good look with a flashlight inside the tank if your tank is rusted, the rust sediment clogs the internal petcock screen choking fuel flow at upper rpm's. Might want to POR50 or KREEM the tank for future trouble free driving.
Bikes:
'84 GPz1100
'06 HD Fatboy
