- Thank you received: 2
Big bore 1166 kits
- s1elr
- blood runs green
02 Jul 2012 00:42 #533231
by s1elr
Big bore 1166 kits was created by s1elr
No eBay APP ID and/or Cert ID defined in Kunena configurationThis is just something I found on ebay. It is interesting, so I thought I would pass along.
It could help someone in a pinch I think, If willing to take a chance. Well
her it is.steve
her it is.steve
- wireman
- Thank you received: 299
02 Jul 2012 00:53 #533234
by wireman
Replied by wireman on topic Big bore 1166 kits
The kz version of the 1170 used to be a big thing back in the 70s-early 80s,ive had a few.
I believe that kit is the biggest you can run with stock gpz/kz1100 sleeves
- LarryC
02 Jul 2012 07:35 #533274
by LarryC
Larry C.
Replied by LarryC on topic Big bore 1166 kits
I can't tell if they're used pistons or some Chinese knock off deals. The only pistons I've ever seen come with circlips like the ones in the photo were inferior, cheap aftermarket snowmobile pistons.
Larry C.
- Motor Head
- Thank you received: 391
02 Jul 2012 10:20 - 02 Jul 2012 10:45 #533296
by Motor Head
Replied by Motor Head on topic Big bore 1166 kits
I'm still in the process of collecting up some parts. But I bought one of these kits in May. I have also bought Clutch Plates from this seller. Running those in the KZ and the ZG with no issues.
Looking at the Pistons in the kit, they look to be Very Good Quality, stock shape for the Dome, Moly coating on the Skirt. These of course are Cast, just like the stock Kaw piston. I'm hoping to do the work on mine, well before the KZR Relay makes it to the NW.
I have been playing around with the chassis before adding more torque/ power. A few of the changes have helped quite a bit, but still playing around.
Last edit: 02 Jul 2012 10:45 by Motor Head.
