no spark in her life!
  • gonbop
  • gonbop's Avatar Topic Author
01 Jul 2012 14:20
#533098
OK, so I recently changed cylinder head gasket and was oh so careful to not mess up the timing and am confident it went back together perfectly; I also went to pods. Long story short, the bike startedperfectly prior and now I cannot get spark? If I arc plugs 1 an 4 against frame, lots of spark, but without arcing the do not spark at all which seems I have a ground issue? Also 2and 3 won't spark no matter what I do... thoughts?
1979 kz650c3
Re: no spark in her life!
01 Jul 2012 16:37
#533126
gonbop wrote: OK, so I recently changed cylinder head gasket and was oh so careful to not mess up the timing and am confident it went back together perfectly; I also went to pods. Long story short, the bike startedperfectly prior and now I cannot get spark? If I arc plugs 1 an 4 against frame, lots of spark, but without arcing the do not spark at all which seems I have a ground issue? Also 2and 3 won't spark no matter what I do... thoughts?
Which ignition is under the points cover -- Points? Kaw elec? Dyna-S? Other?
arc plugs 1 an 4 against frame -- uncertain of meaning :unsure:
Good Fortune! :)
  • gonbop
02 Jul 2012 22:04
#533470
Points... but I got it running, was steered in the wrong direction on jetting, went back to 100 and fired right up!
1979 kz650c3
