cylinder head, valves, redo or not?
- fireglass
01 Jul 2012 01:26 #532950
by fireglass
cylinder head, valves, redo or not? was created by fireglass
Ok so I have a 1980 kz650 f1 I did a compression check, a dry and wet test the numbers where almost the same no.1 105 no. 2 125 no.3 120 no.4 150 I didn't hold the throttle open so the only thing it maybe told me is the rings are still good. Checked the valves exaust no. 1 .005 no.2 .005 no.3 .004 no.4 .006 intake no.5 .004 no.6 .004 no.7 too thick, could not get a gage in no.8 .004
checked the shims no. 1 097 no. 2 200 no. 3 250 no. 4 245 no.5 200 no. 6 200 no. 7 205 no.8 250
I don't think the bike has ever had the valaves lapped if I lap them how much well the shims change and witch way well they go up in numbers or down and how to check the valves to see if there bent or not? thanks..Lance
- Motor Head
- Thank you received: 391
01 Jul 2012 01:38 #532955
by Motor Head
Replied by Motor Head on topic cylinder head, valves, redo or not?
Do a Leak Down Test, that will show you where any compression is leaking. Dry then wet, just like the comp test.
- bountyhunter
- Thank you received: 337
01 Jul 2012 01:45 - 01 Jul 2012 01:46 #532958
by bountyhunter
Replied by bountyhunter on topic cylinder head, valves, redo or not?
105 on #1 is way below service spec. Need to hold throttle open to get real number.
Last edit: 01 Jul 2012 01:46 by bountyhunter.
- fireglass
01 Jul 2012 01:52 #532960
by fireglass
Replied by fireglass on topic cylinder head, valves, redo or not?
I'v already tore it down so to late to do a new test I think most of the prolem is the valves. Lance
