KZ400 - Hesitation and dies after high rev...
- esion
- 1976 KZ400
29 Jun 2012 10:36 - 29 Jun 2012 11:08 #532592
by esion
Current Project - 1976 KZ400 conversion to Cafe Racer Styled Bike
KZ400 - Hesitation and dies after high rev... was created by esion
I have a '76 KZ400 which seems to have a struggling engine issue. The bike will idle just fine and sounds great but it has a lag between giving throttle and the response of the engine. Furthermore, when I rev up to 8k it will return to about 1k and then sputter and die.
I thought maybe it was running too lean so I opened it up a bit but it still had the problem. Last weekend I replaced the spark plugs with new stock ones from the owners manual.
I have been researching the problem and found several similar issues. I have not tried any of these yet, but was wondering what everyone else thought.
1) Fuel filter needs replacement
2) Clogged fuel lines
3) Clean carbs (maybe re-jet even)
4) Electrical issue (I have another post today about a dead battery after 7 days)
5) Air filter needs replacement
Anything else it could be?
Last edit: 29 Jun 2012 11:08 by esion.
- Motor Head
- Thank you received: 391
29 Jun 2012 11:03 #532596
by Motor Head
Replied by Motor Head on topic KZ400 - Hesitation and dies after high rev...
Get your charging/ electrical sorted before going into the carbs. It could be related sounds like, from your other posts.
- Thank you received: 2829
29 Jun 2012 11:55 #532609
by 650ed
+1 !! Messing with the carbs before sorting out your electrical problem will only give you headaches. Ed
Replied by 650ed on topic KZ400 - Hesitation and dies after high rev...
Motor Head wrote: Get your charging/ electrical sorted before going into the carbs. It could be related sounds like, from your other posts.
- P21
- Thank you received: 34
29 Jun 2012 14:08 #532620
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic KZ400 - Hesitation and dies after high rev...
check your advancer might need lube should snap back when rotated
