77kz 1000 bolt next to foot clutch?
- GTCpopo
28 Jun 2012 21:30 #532461
by GTCpopo
77kz 1000 bolt next to foot clutch? was created by GTCpopo
Can anyone tell me what the bolt that is riight under the 1 n234 stamp on the block and is like a foot long and only threads on the end. It some how came out when I tightened it back in there and now my clutch feels like it is always engaging. Is that some type of clutch adjuster?
- les holt
- Thank you received: 288
28 Jun 2012 22:15 #532471
by les holt
Replied by les holt on topic 77kz 1000 bolt next to foot clutch?
You sure it's like clutch always engaging? If I'm understanding what your getting at I would say the clutch is slipping. To put it simple, tighten all the bolts that are on the same cover as the bolt your referring to, then adjust your clutch handle to have the amount of play you like. If your not able to get the results you need, post up again and we will get farther into the problem
Les
Les
- GTCpopo
01 Jul 2012 01:36 #532954
by GTCpopo
Replied by GTCpopo on topic 77kz 1000 bolt next to foot clutch?
Do you know were I can find a bare frame kz1000 with a title?
