- Thank you received: 8
Tach gear cover?
- gwolever
27 Jun 2012 11:35 #532087
by gwolever
1982 KZ1000 CSR
Tach gear cover? was created by gwolever
Hey guys.
With the new Acewell gauge, I am not going to need the mechanical tach cable any more:
So what do I do with the tach gear connection on the front of the engine?
Is there a way to plug the connector without having to use the old tach cable?
Thanks.
Attachment 082.JPG not found
Thanks.
1982 KZ1000 CSR
- baldy110
- Thank you received: 512
27 Jun 2012 12:38 #532092
by baldy110
Replied by baldy110 on topic Tach gear cover?
I remove the drive unit from the head, take out the seal, clean it up really good and fill the hole with epoxy then re-install.
- Samwell
- Thank you received: 1
27 Jun 2012 13:42 #532101
by Samwell
Replied by Samwell on topic Tach gear cover?
Remove the tach drive and see you can't find an acorn type nut to fit.
- gwolever
- 4TheKZ1000
- Visitor
27 Jun 2012 15:20 - 27 Jun 2012 15:27 #532119
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Tach gear cover?
Plug it....Z1-Entreprises.
Tachometer Drive Block Off Kawasaki KZ900 Z1 KZ1000
PM81-2290 Takes the place of OEM: 92087-5001----
Fits KZ1000 (thru 80) KZ900 Z1. Eliminates the tach.
$43.50
$43.50
Attachment bike361.JPG not found
Last edit: 27 Jun 2012 15:27 by 4TheKZ1000. Reason: info
- gwolever
28 Jun 2012 14:02 #532376
by gwolever
1982 KZ1000 CSR
Replied by gwolever on topic Tach gear cover?
Thanks 4TheKZ1000. Ordered one last night. Appreciate it.
1982 KZ1000 CSR
- 4TheKZ1000
- Visitor
28 Jun 2012 15:51 #532399
by 4TheKZ1000
Your welcome, the item will be hard to install. This is by design, they are made to have tight clearance. Clean the hole, lube the plug and two o-rings. I used a plastic headed hammer to install mine. Just take it easy and it will work out fine.
- gwolever
30 Jun 2012 22:09 #532897
by gwolever
1982 KZ1000 CSR
Part came in today and works perfectly. Was a little nervous as it says it is for up to 80 and mine's an 82, but it looked like it would fit perfectly.
You were right. Had to tap it in a little as it was a tight fit. Perfect.
Thanks again 4TheKZ1000
Attachment 015_2012-06-30.JPG not found
1982 KZ1000 CSR
- 4TheKZ1000
- Visitor
30 Jun 2012 23:31 #532912
by 4TheKZ1000
the right fix at the right price and it looks custom and also gr8. well done grasshopper.
