81-82 ish kz1100 engine in 79kz1000 frame?
- adam90xj
26 Jun 2012 20:38 #531981
by adam90xj
81-82 ish kz1100 engine in 79kz1000 frame? was created by adam90xj
So I have a kz1000 in pieces that needs cylinders bored and possibly a different crank/rods. My buddy has a complete kz1100 motor that I could get for a fraction of the cost of the pistons and engine work. Are the mounts the same? Both are shaft drive. I figured I'd ask before I tried to heave that heavy ass motor into that frame or lay it on it's side and set the frame on top of it.
Any Ideas?
Thanks,
Adam
Any Ideas?
Thanks,
Adam
- faffi
- Thank you received: 36
27 Jun 2012 03:48 #532045
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Replied by faffi on topic 81-82 ish kz1100 engine in 79kz1000 frame?
Although I do not know with 100% certainty, I doubt very much that the mounts are the same. The old 1000 is rigidly mounted whereas the 1100 is rubber mounted. It is also shaft drive - is yours? I'm not sure if they interchange even if both are shaft driven, but that must be verified. Or if the KZ1100 is a GPz or R unit, it will be chain drive but still has a different engine block that is partially rubber mounted.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- gpz1170
- Thank you received: 10
27 Jun 2012 14:49 #532115
by gpz1170
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
Replied by gpz1170 on topic 81-82 ish kz1100 engine in 79kz1000 frame?
Starting in 1981 the mounting is totally different. It can be done but with allot of fabrication.
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- adam90xj
28 Jun 2012 08:26 #532326
by adam90xj
Replied by adam90xj on topic 81-82 ish kz1100 engine in 79kz1000 frame?
Thanks. Modification is no problem. Just wanted to know what I was getting into before trying to drop it in. I wonder if there are any mounts that line up? I'll post up what I find when I set the motor in there to mock it up. Yes, they are both shaft drive motors.
