Oil turning milky white...
  • schmol
  • schmol's Avatar Topic Author
09 Jun 2006 08:43
#53175
In a co-workers '78 KZ1000. He assures me that it's air cooled and ther isn't anyway water is getting into the oil. Can anyone verify that the '78 KZ 1000 is indeed air cooled? If it is, can someone tell me how the oil is getting milky white?
He has already changed the oil twice and both times it has turned white. Can excess gas do the same thing to the oil?
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Oil turning milky white...
09 Jun 2006 08:48
#53177
It's air cooled , I don't know about the oil, unless someone is messing with his engine and he doesn't know it.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • Pterosaur
  • Pterosaur's Avatar
09 Jun 2006 09:06
#53178
There's probably several hundred people ready to dive in to the air-cooled aspect, so I'll pass on that one....B)
My best guess on where the DiHydrogen Monoxide showing up in your friend's ex-prehistoric biomass is likely to be caused by either using something just this side of a firehose to wash the bike down and/or riding in torrential, cat, dog, hampster and the odd Gris-ley bear downpours.
Short of a missing oil-filler plug, the usual suspect here would be the oil breather, and the entry point depends on how your pal's airbox/air cleaner(s) (pods) are set up...;)
  • steell
  • steell's Avatar
09 Jun 2006 09:24
#53181
Condensation is what's causing the oil to turn milky.
My guess is he takes short rides and the oil never gets to operating temp and never boils off the condensation.
The solution is to take longer rides or to allow the motor to idle a lot longer to get it to operating temp.
Oil temp needs to get to at least 200 degrees F.
  • hwms
  • hwms's Avatar
09 Jun 2006 09:33
#53183
I agree with the condensation theory.
Inadequate ventilation (pluged crankcase breather) will cause condensation buildup and will result in contamination of the oil.
  • Pterosaur
09 Jun 2006 09:50
#53187
That too, come to think of it. Before I got chased out of Florida on unrelated charges, I'd see condensation corruption every so often during wet spells...
  • OKC_Kent
  • OKC_Kent's Avatar
09 Jun 2006 11:43
#53199
Pterosaur wrote:
You were so bad even Florida didn't want ya? :lol:
Cashion, OK
  • Pterosaur
09 Jun 2006 12:57
#53210
OKC_Kent wrote:
...You were so bad even Florida didn't want ya? :lol:
Not the State of Florida, per se, just a certain Pinellas County judge...
Quite a story... :whistle: B)
  • schmol
09 Jun 2006 13:00
#53213
Thanks for all of the info guys, I'll pass it along.
