Piston Rings for kz750 b4
- Pop147
25 Jun 2012 18:52 #531670
by Pop147
Piston Rings for kz750 b4 was created by Pop147
Dose anyone know a place to get some piston rings for a 1979 kz 750 b4?
I just got the case split and was going over the parts and found that the oil ring for the left side piston is cracked.
- bountyhunter
- Thank you received: 337
26 Jun 2012 03:36 - 26 Jun 2012 03:38 #531812
by bountyhunter
Replied by bountyhunter on topic Piston Rings for kz750 b4
No eBay APP ID and/or Cert ID defined in Kunena configurationI see them cheap on ebay often. Kawi rings came in three sizes: stock, +0.50mm over, and 1.0 mm over. The aftermarket ones came in 0.25, 0.50, 0.75, and 1.0mm over. be sure to get the size you need.
Shame that cyclewarebales.com recently stopped carrying them. They had OEM piston/ring/pin sets for $36 each in all four sizes. I used them to rebuild my 750 twin, but they no longer list them.
Last edit: 26 Jun 2012 03:38 by bountyhunter.
- Pop147
26 Jun 2012 12:06 #531869
by Pop147
Replied by Pop147 on topic Piston Rings for kz750 b4
Im guessing i will need stock but how will i know.
- bountyhunter
26 Jun 2012 15:52 #531924
by bountyhunter
Read the top of the piston, it should be stamped on it. Also can measure the bore if you have the tool.
- Pop147
26 Jun 2012 20:29 #531977
by Pop147
I guess while i have you interested ill ask about the piston wear. How do theses look?
- adam90xj
26 Jun 2012 21:10 #531990
by adam90xj
Replied by adam90xj on topic Piston Rings for kz750 b4
Only way to know is to measure them. You can pick up a digital caliper for cheap now-a-days to measure the piston. If you don't have the tools you could always swing by the local machinist and ask them to measure the pistons and bores.
- bountyhunter
26 Jun 2012 21:58 - 26 Jun 2012 21:59 #532000
by bountyhunter
I can't tell wear from a picture. The scuffed sides don't look good to me.
If I was going to put the work into the engine, I would at least buy those two new standard piston/ring sets listed on ebay for $50 and have the cylinders honed enough to deglaze them and install new standard pistons and rings (assuming cylinder wear is minimal). Need to measure cylinders to know.
Last edit: 26 Jun 2012 21:59 by bountyhunter.
