Car tach on kz 700
  • ready2ryde1985
  • ready2ryde1985's Avatar Topic Author
  • got to love these kzs
Car tach on kz 700
24 Jun 2012 18:05 - 24 Jun 2012 20:29
#531479
So I got this cool new autometer tach... :woohoo:
I have looked up and tryed all otions and this is what i have got. :silly:
so two dioeds and a resistor is what I read on our archive sweet 5 bucks..
come home try it out no go :sick:
tryed a y with the two diodes to each coil and no resistor no go :angry:
hook it to one coil reads 500 rpm when bike idols at 1000 checked by the kz dr. :huh:
since my bike had an eletric tack I thought try the stock pickup same reading 500 rpm at 1000 so atleast im learning .. but now what??? :dry:
[attachment:1]IMG_20120623_234333.jpg[/attachment]
Attachment IMG_20120622_181953.jpg not found
I could realy use some help tryed the two diagrams i have found on here to no avil..
not real good with wire please help!!
84 kz 700 a1
82 kz550 ltd
Last edit: 24 Jun 2012 20:29 by ready2ryde1985. Reason: trying to move to right catigory
  • ready2ryde1985
Re: Car tach on kz 700
24 Jun 2012 21:47
#531511
com on guys no one has had this issue ??? I have to make this thing work.. so far all i can come up with is finding a way to dubble the pulses from a single coil.. or from the tach pick up.. also should mention it has been switched to 4 cyl by the dip switches
84 kz 700 a1
82 kz550 ltd
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
24 Jun 2012 22:03
#531514
Not familiar with the diagrams you mentioned.
You are getting half the pulses you should be getting but I would expect you to get twice as many due to the wasted spark aspect of these ignitions.
Point us to the diagrams.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
24 Jun 2012 22:03 - 24 Jun 2012 22:11
#531515
when you wired the dioeds and res did you wire them correct. they need to be wired a certin way. they have a polarty and can only go one way, the wrong way no dice. see my pic as I have done this also. in the instructions the tach needed to be set for a 4 6 or 8 cylinder. if it was a 8 you did nothing. if it was a 6 cylinder you cliped a brown wire. if it was a 4 cylinder you cliped two wires. was this the case with your tach?
Last edit: 24 Jun 2012 22:11 by 4TheKZ1000. Reason: info
24 Jun 2012 22:20
#531518
Did some quick Google-fu and found that the diode/resistor network was called for when using a tach (that was set up for a 4 cylinder) on a 2 cylinder bike. That way you are getting the pulse from both coils without them interfering with each other. Is this sounding right?
Have you tried running it in 8 cylinder mode with your current setup?
24 Jun 2012 22:25
#531520
That makes sense but if his tach is capable of sensing a 4 cylinder setup. why does he need the diode/resistor network?
  • ready2ryde1985
24 Jun 2012 23:33
#531534
so to put this down once more ..
i hook up to one coil 500 rpm
same if i hook into stock tach pickup
now the fun stough
Attachment TachAdapter.gif not found
i have tryed this powered and not switched and tryed almost every veriation and still no good
i am not shure if the diodes are not right or what but it doesnt pick up at all no matter witch way the are facing
as for the resistor im at a 470k diodes are 1.5 amp 2761114
i dont realy wana spend 80 on a converter i got the tach for 100 so if i have to buy the 80 $ adapter im 200 in and i could have just went with a bike tach for that
84 kz 700 a1
82 kz550 ltd
  • ready2ryde1985
24 Jun 2012 23:42
#531536
dyna tach pick up splitter 20$
Attachment untitled_2012-06-24.png not found
this is autometers 80
i didnt use 100k diodes i think mine are heavy could that be my issue?
84 kz 700 a1
82 kz550 ltd
25 Jun 2012 00:02 - 25 Jun 2012 00:30
#531544
I don't think the diodes being too heavy is going to be an issue. They are acting like check valves to keep the coils from crosstalking to each other. The resistor is a failsafe in case the diode(s) short out.
Do you have the install instructions for the tach?
The only one I can find on the net shows the input (green wire) coming from the negative side of the coil.
This is what I am looking at:
www.autometer.com/productPDF/1244.pdf
Could it just be a setup error? Having an offset of exactly half the expected readings sounds like a setup issue.
I'm looking at your circuit and it's definitely different than 4thekz1000's. Yours has the diodes backwards and you have a pullup resistor on the +12VDC side. I'm going to guess that your circuit is for a different mfr of tach. Try his circuit.
Last edit: 25 Jun 2012 00:30 by DiamondSkyBlue1000.
  • ready2ryde1985
25 Jun 2012 01:20
#531556
Ok the digram I posted was found on here I noticed the flip asumed they were for a dif tach I didn't have to run 12 v power ti the green wire autometers directions say to just hook it to the coil .. all I know is I am not the only one with this isue so I will call autometer tomarro
84 kz 700 a1
82 kz550 ltd
25 Jun 2012 01:43
#531559
Could you let us know what you find out?
  • ready2ryde1985
25 Jun 2012 21:03
#531703
auto meter was no help
had some car guys say to hook it to the hot lol i dont see that working
all i want is some in line interpeter
one beep in ============ two beeps out
is there no simple adapter for this ..
84 kz 700 a1
82 kz550 ltd
