How much piston damage is too much?
  • Tariq4
  • Tariq4's Avatar Topic Author
23 Jun 2012 17:12
#531291
Hi everyone,
I've been taking apart my engine, trying to figure out why I cannot get it started. A compression test shows compression way below spec. The service manual says 138 is the lower limit and I'm getting 100 on two cylinders, 80 on the other two. So, it's either the valve clearance or the piston rings. Once I got the top end of the engine off, I discovered that one of the pistons are scored. A previous owner must have, at some point, installed the wrong size spark plug and damaged the piston head. Luckily it didn't punch through. But how much damage is too much damage? I'm not exactly crazy about the idea of sourcing another piston. Here's a photo. What do you guys think? (That is, aside from the carbon buildup - holy crap!)
Tariq
  • Tomolu5
  • Tomolu5's Avatar
Re: How much piston damage is too much?
23 Jun 2012 17:41
#531296
I would wanna replace it for fear of that causing a hot spot, or detonation. I'm no expert, just my two cents
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
  • faffi
  • faffi's Avatar
23 Jun 2012 17:58
#531300
I would probably consider keeping the piston, but only if I could polish everything out so that there are no signs of the punch, just a smooth dimple. And that there is still sufficient thickness left to retain integrity. But generally, these old pistons were way over-engineered for normal use and can easily tolerate some thinning of the piston crown without much risk of failure.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
23 Jun 2012 19:37
#531318
run as*is
23 Jun 2012 20:12
#531327
Here's one that shows too much damage to re-use; it makes your piston look pretty good.
Attachment HoledPiston.jpg not found
  • Tariq4
23 Jun 2012 21:08
#531335
Thanks everyone. Any particular recommendations for cleaners/solvents to clean the pistons and valves? A friend recommended carb cleaner....?
  • MDawnz1
  • MDawnz1's Avatar
29 Jun 2012 01:53
#532538
Quick Answer,
That's NOT to much if the bike is stock.
Just knock off the high spots and sharp edges,
and it will last forever.
1974 Z1a, still 903
  • trianglelaguna
  • trianglelaguna's Avatar
29 Jun 2012 02:01
#532540
it is a bike and you should try and eliminate all flaws when and as soon as discovered...
it is not a tractor...
sure it will run...sure it is safe but
bore kit and work 1000.00
gaskets and time 2-300
piece of mind
priceless
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
