Mechanical eye candy
- Roadflyer
22 Jun 2012 11:12Attachment kzmotor001.JPG not found
When I bought this bike a couple months ago it showed all of it 32 years of age. The PO had even used a nylon scuff pad on a die grinder to clean up the covers ( scratched the crap out of them), followed by a gloss black touch up with overspray everywhere.
It has a newly installed 1045 kit and valve job, but I found the cam timing to be off 1 tooth on the intake with 1 valve on the tight side and 1 too loose by 1 shim size. Compression is an even 180 on all 4 now.
I sand blasted the engine and painted it with PJ1 satin black engine paint and polished all the covers. I am very pleased with the way it turned out. The frame is all stripped down/ sandblasted and ready for paint.
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- redneckcarrow
The following user(s) said Thank You: Roadflyer
Re: Mechanical eye candy
22 Jun 2012 11:45
Looks like the build is going to be very nice !!
- wireman
22 Jun 2012 11:47Attachment quag_2012-06-22.jpg not found
- damarble
22 Jun 2012 12:18 - 22 Jun 2012 12:18
Sooo... :whistle: Where do you live and what time do you leave for work?
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
Last edit: 22 Jun 2012 12:18 by damarble.
- Roadflyer
23 Jun 2012 00:13
Thanks for the compliments. I'll post other pics of the build as I get into it. I will probably paint the frame soon and leave the rest for winter.
Last edit: 22 Jan 2013 20:06 by martin_csr.
- Kitten Tooth
23 Jun 2012 04:42
is it.. edible? hahhaaa damn.
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- LarryC
23 Jun 2012 07:36Roadflyer wrote:Attachment kzmotor001.JPG not found
That looks GREAT!
Larry C.
- Old Man Rock
23 Jun 2012 10:23
"Where do you live and what time do you leave for work?"... :laugh: :laugh: :laugh:
Schwiiiiiiiiiiiiiiiiiiiiing!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Gabe42
06 Feb 2013 00:40
That is just simply BEAUTIFUL! There is nothing like the Dual Over Head Cam Engines
