Valves chatter and tick more when engine is hot?
- AaronOregon
- Live Hard, Ride Free
Aaron
1980 KZ750E - Pods - 4 into 1
- wireman
- Thank you received: 299
- Thank you received: 2098
AaronOregon wrote: Sounds good cold, but once it heats up after riding for awhile and I stop the valvetrain is noisy. I just checked all the valve clearances a month or so ago. They are all within limit, but some may be on the tighter side. Is this chatter the tighter ones when they expand? It's not the chain as I just installed a manual adjuster and it is awesome! Thanks! Aaron
Could be the cold thicker oil is doing more padding between the cam lobes and buckets when the engine is first started. And when warmed, the oil thins to its normal operating viscosity.
Cam chain noise is often reduced by a good carb sync.
- DiamondSkyBlue1000
- Thank you received: 40
Yes! Thank you! Can't emphasize that enough. I think a lot of guys don't make that association and dismiss it too soon as a culprit for a noisy valvetrain.
- bountyhunter
- Thank you received: 337
- RonKZ650
- Thank you received: 240
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Motor Head
- Thank you received: 391
- AaronOregon
Aaron
- AaronOregon
Carb sync done last month with gauges.
