plugging tachometer hole
- gonbop
21 Jun 2012 00:49 - 21 Jun 2012 00:50 #530673
by gonbop
1979 kz650c3
plugging tachometer hole was created by gonbop
Hi all, I am wanting to pull my tach and cap the hole though I am leaving the little stem in, any thoughts?
Thanks
Thanks
1979 kz650c3
Last edit: 21 Jun 2012 00:50 by gonbop.
- 750steve
21 Jun 2012 14:29 #530752
by 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Replied by 750steve on topic plugging tachometer hole
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- damarble
- Thank you received: 13
21 Jun 2012 18:38 #530812
by damarble
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
Replied by damarble on topic plugging tachometer hole
That is pretty much my plan as well. On a side note, electrical tape wrapped around the stub of the broken cable does not hold up worth a damn.
- gonbop
22 Jun 2012 02:47 #530943
by gonbop
1979 kz650c3
Replied by gonbop on topic plugging tachometer hole
Great idea, very much appreciate it!
1979 kz650c3
- damarble
28 Jun 2012 12:20 #532354
by damarble
I couldn't find a M18 bolt so I welded a plug into the end of the threaded part of the tach cable. Clean solution and best of all free.
- Ederer
- Thank you received: 5
04 Oct 2012 10:56 #552409
by Ederer
1980 KZ650 Build
kzrider.com/forum/11-projects/552156-kz6...ect-first-time-build
Replied by Ederer on topic plugging tachometer hole
Seems like an ordinary 02 sensor plug would work (m18x1.5)? It would need to be drilled for the stub, but I think it might work. I'm needing to plug mine so I'll report back if it works.
This is what I'm thinking:
www.summitracing.com/parts/fst-30169
1980 KZ650 Build
- mark1122
- Keep twisting it
- Thank you received: 109
04 Oct 2012 12:59 - 04 Oct 2012 13:00 #552425
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic plugging tachometer hole
i took the threaded end off of the cable, glued a resized penny into it, then just used it as a cap .
works fine. no stem used.
or u can just buy a block off from verious supliers.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 04 Oct 2012 13:00 by mark1122.
- DesertKZ
- Thank you received: 20
05 Oct 2012 00:06 #552527
by DesertKZ
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
Replied by DesertKZ on topic plugging tachometer hole
Just curious why people are blocking theirs off, are you all running digital tachs or something? Mine's leaking a little and I was just curious before I replace the oring/seal.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
