Engine Ignition Electrical Question
- retcol
20 Jun 2012 20:45 #530595
by retcol
2005 HD Softail Deuce
2003 Kawasaki ZRX1200R
1981 Honda CB900F Super Sport
1978 Kawasaki KZ1000A2 Project Bike
Engine Ignition Electrical Question was created by retcol
I pulled the engine out of my 78 KZ1000A and am getting ready to install the engine out of my 80 KZ1000B LTD and noticed the ignition wiring is different. The 78 has points and a 2 wire lead out of the ignition and the 80 has electronic ignition and has a 3 wire lead. How do i connect the 3 wire lead into the 78 2 wire wiring harness? A friend said I had to install the entire wiring harness from the 80 into my 78 frame for the engine wiring to work. Any advice would be appreciated.
- 4TheKZ1000
- Visitor
20 Jun 2012 21:25 - 20 Jun 2012 21:28 #530611
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Engine Ignition Electrical Question
one wire goes to the hot 12volt
one wire is 1 and 4 cylinder to the coil
one wire is 2 and 3 cylinder to the coil
that makes 3 wires.
this link is for a dyna-s but are the same
www.wgcarbs.com/forum/index.php?action=d...c=1970.0;attach=3320
that makes 3 wires.
Last edit: 20 Jun 2012 21:28 by 4TheKZ1000. Reason: add info
- mtkawboy
- Thank you received: 16
20 Jun 2012 21:44 #530618
by mtkawboy
Replied by mtkawboy on topic Engine Ignition Electrical Question
I sort of have almost the same problem. Im trying to put an earlier ignition switch in an 80 1000 LTD {lost keys} and the 80 has an extra yellow wire. Is there any way to use that earlier switch in my 80 ?
