- Thank you received: 6
If it isn'r one thing it's another!
- badrhino
18 Jun 2012 16:00 #530116
by badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
If it isn'r one thing it's another! was created by badrhino
So.....there I was, got my valves adjusted and put the valve cover back on. I go to put my spring and cap back on the cam chain tensioner and am tightening it up and *SNAP* just broke the threads or something off if it. Are you kidding me? I don't think this bike wants to get back on the road. Where can a guy find a good cheap cam chain tensioner?
Should I go stock or aftermarket?
It is for a KZ1000J motor.
Franken Z!
- Powerstroke_fan
- Thank you received: 83
18 Jun 2012 17:56 - 18 Jun 2012 17:57 #530145
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic If it isn'r one thing it's another!
you can buy the aftermarket ones decently cheap. And also depends on if you can remember to check it and adjust it properly. Dont want the cam chain getting loose and blowing up the motor. I know you could get some off ebay and probably z1 enterprises.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 18 Jun 2012 17:57 by Powerstroke_fan.
- Old Man Rock
- Thank you received: 225
18 Jun 2012 20:22 - 18 Jun 2012 20:22 #530190
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic If it isn'r one thing it's another!
"just broke the threads or something off if it."... Image...?
What exactly broke...?
A: Two bolts securing the tensioner into the head...
B: Bolt that holds the spring loaded tensioner bolt into head/chain...
If B, you can always tap it out for a bigger bolt for locking into position...
Or you can drill and tap on the end like after market tensioners...
Or get a new after market tensioner (APE, Z1, American Classix etc...)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 18 Jun 2012 20:22 by Old Man Rock.
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
18 Jun 2012 20:23 #530191
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic If it isn'r one thing it's another!
I have an ape manual cam chain adjuster on my z1 I bought it at z1 enterprises and it was the best thing I've bought for it.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Old Man Rock
18 Jun 2012 20:51 #530198
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Hey Jim
Did they provide instructions for adjusting and if so, accurate...?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- oldkaws4ever
18 Jun 2012 21:38 #530207
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
It was just like the factory one, then you turn the bolt till its semi tight and back it out 1/4 turn and tighten the nut.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- badrhino
18 Jun 2012 22:10 #530219
by badrhino
Franken Z!
Replied by badrhino on topic If it isn'r one thing it's another!
It was ( :whistle: lol
The spring holder thingy majiggy on the side.
See illustration.
See illustration.
Franken Z!
- badrhino
18 Jun 2012 22:10 - 18 Jun 2012 22:11 #530220
by badrhino
Franken Z!
Franken Z!
Last edit: 18 Jun 2012 22:11 by badrhino.
- badrhino
19 Jun 2012 00:31 #530251
by badrhino
Franken Z!
Yes, after further inspection the cap definitely snapped the threads off of the tensioner body. It looks like it is made out of pot metal.
Franken Z!
- gpz1170
- Thank you received: 10
19 Jun 2012 14:40 #530339
by gpz1170
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
Replied by gpz1170 on topic If it isn'r one thing it's another!
should have one of those lying around, if so you can have it. I always use the manual adjuster
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- badrhino
19 Jun 2012 17:13 #530365
by badrhino
Franken Z!
I ordered a used one off of fee-bay already. Thanks!
I really don't even see how these things tension the chain the way they are set up. :blink:
Franken Z!
- Motor Head
- Thank you received: 391
19 Jun 2012 22:11 #530415
by Motor Head
Replied by Motor Head on topic If it isn'r one thing it's another!
