vacum lines
- nitrochristian
18 Jun 2012 02:42 #530035
by nitrochristian
78 KZ650
96 Ford Bronco
vacum lines was created by nitrochristian
alright kz brothers, i went to pods so what to do with the two vac lines comming from carbs im using a custom fuel tank so no vac line to the tank. just need to know the best way to set them up. bike is a 1978 kz650b.
78 KZ650
96 Ford Bronco
- Thank you received: 2098
18 Jun 2012 07:49 #530058
by Patton
Vent nipples should exit (through a hose) to open air.
Replied by Patton on topic vacum lines
Unused vacuum nipples should all be capped.nitrochristian wrote: alright kz brothers, i went to pods so what to do with the two vac lines comming from carbs im using a custom fuel tank so no vac line to the tank. just need to know the best way to set them up. bike is a 1978 kz650b.
The following user(s) said Thank You: nitrochristian
