Elimination of Valve Cover Air Hoses
- retcol
17 Jun 2012 17:12 - 17 Jun 2012 17:12 #529903
by retcol
2005 HD Softail Deuce
2003 Kawasaki ZRX1200R
1981 Honda CB900F Super Sport
1978 Kawasaki KZ1000A2 Project Bike
Elimination of Valve Cover Air Hoses was created by retcol
I just bought a 1980 KZ1000 LTD engine to put into my 1978 KZ1000A frame. The 80 LTD engine has 2 air hoses coming out of the valve covers that meet into a device that also has 2 smaller hoses coming out to the carb insulators. My 78 engine doesn't have this plumbing and I assume it is part of the EPA pollution control system that year. My question is this: can I remove this contraption and just plug off those hose tubes coming out of the valve covers or better yet put my 78 valve cover on the 80 engine? Will the engine run OK without this air venting plumbing? Any other modifications necessary if you remove this junk? Thanks for your answers.
Last edit: 17 Jun 2012 17:12 by retcol.
- peter1958
- Banned
- Thank you received: 198
17 Jun 2012 17:16 #529905
by peter1958
Replied by peter1958 on topic Elimination of Valve Cover Air Hoses
you can just run the hose over to the other or cap them. I dont think the other valve cover will work.
- 4TheKZ1000
- Visitor
17 Jun 2012 17:50 #529915
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Elimination of Valve Cover Air Hoses
they make covers that look gr8 see pic they are made by APE
- MFolks
- Thank you received: 540
17 Jun 2012 17:59 #529917
by MFolks
Replied by MFolks on topic Elimination of Valve Cover Air Hoses
Make sure to block, or cap off any open vacuum lines if you remove the air switch housing(the object the cover vents went to) or the engine will run lean.Don't forget the air supply line(a large hose) that supplied fresh air to the reed valves in the valve covers. It needs capping off too.
- retcol
17 Jun 2012 21:26 #529967
by retcol
Replied by retcol on topic Elimination of Valve Cover Air Hoses
Thanks for the advice. The APE cover looks great too.
- 4TheKZ1000
- Visitor
17 Jun 2012 21:35 - 17 Jun 2012 21:38 #529968
by 4TheKZ1000
if you do the ape covers block the passages to the upper cover. 10mm tap and a machine screw that matches the tap size and thread pitch. it will keep oil out of the cover.use a machine screw about 1/2 to 1 inch long. the 10mm goes in easy with little force. dont get the shavings in the head or engine. use a sealer on the screw when you install.
Attachment bike009.JPG not found
Last edit: 17 Jun 2012 21:38 by 4TheKZ1000. Reason: add info
