1982 kz1000 ltd exhaust fitting to a 77 kz1000
- wdizard
17 Jun 2012 01:41 #529763
by wdizard
1982 kz1000 ltd exhaust fitting to a 77 kz1000 was created by wdizard
Can I put an exhaust from a 1982 kz1000 ltd onto a 1977 kz1000?
- wireman
- Thank you received: 299
17 Jun 2012 01:56 #529767
by wireman
Replied by wireman on topic 1982 kz1000 ltd exhaust fitting to a 77 kz1000
Yes youll need the split collars from 77 motor,probably need to modify the rear brackets from exhuast to frame
- wdizard
17 Jun 2012 01:59 #529769
by wdizard
Replied by wdizard on topic 1982 kz1000 ltd exhaust fitting to a 77 kz1000
what are split collars?
- wireman
17 Jun 2012 02:01 #529771
by wireman
The 2 pieces that go on the header tubes where the bolt to head on each cylinder behind the big cast pieces the studs go through.
- MFolks
- Thank you received: 540
17 Jun 2012 02:02 #529772
by MFolks
Replied by MFolks on topic 1982 kz1000 ltd exhaust fitting to a 77 kz1000
They are what grips the exhaust pipes, so the exhaust clamps will hold the system to the exhaust ports.
- wireman
17 Jun 2012 02:03 - 17 Jun 2012 02:04 #529773
by wireman
The pieces on left side and top of picture
Attachment Z1E_0778.jpg not found
Last edit: 17 Jun 2012 02:04 by wireman.
The following user(s) said Thank You: wdizard
- Thank you received: 2098
17 Jun 2012 10:08 - 17 Jun 2012 10:10 #529815
by Patton
Replied by Patton on topic 1982 kz1000 ltd exhaust fitting to a 77 kz1000
Last edit: 17 Jun 2012 10:10 by Patton.
- wdizard
17 Jun 2012 18:05 #529919
by wdizard
I think the split collars are not used on the 82, I see that there is a thick collar on the headers. Is anyone familiar with this?
- MFolks
17 Jun 2012 18:29 #529929
by MFolks
My 1982 GPz 1100 B2 has the split collars. It came with them, and is used on the Kerker on it now.
I understand the Suzuki copper washers(gaskets) are thicker than the Kawasaki one's are. Z1 sells both gaskets.
