eliminator help!!
  • shimkus
  • shimkus's Avatar Topic Author
eliminator help!!
16 Jun 2012 19:01
#529666
so ive got the bike running but only with the choke all the way on and when i throttle even slightly it stalls.. changed the oil and cleaned the spark plugs.. anyone know what the problem is?? please im dying to ride this sweet bike!
'81 kz650h1
'88 el250-d
  • TexasKZ
  • TexasKZ's Avatar
Re: eliminator help!!
16 Jun 2012 19:10
#529672
Most likely a massive air leak.
Rubber boots (intake manifolds) between carbs and engine can be cracked, can leak where they contact the head and the edged can roll over when the carbs are installed. The boots to the airbox can do similar things. To test for this, start the engine and spray carb cleaner, brake cleaner, or even WD40 carefully around each and every boot. If the idle changes, you have found a leak.
The problem could also be badly clogged carbs or maybe ridiculously low fuel level in the carb bowls.
There are many discussion threads on these topics and some dang good tutorials in the file base.
  • shimkus
16 Jun 2012 19:31
#529679
yeah i was looking around and some people say seafoam it, the boots are in good shape and the carbs/fuel lines are clear.. but thanks i will check out that other stuff
'81 kz650h1
'88 el250-d
