Bluing on only one pipe?
- RumbleFish
16 Jun 2012 18:17 #529646
by RumbleFish
1980 KZ1000 LTD
Bluing on only one pipe? was created by RumbleFish
Hi Folks,
Just joined the forum as I used to ride a 2008 T100 Triumph but I recently picked up a 1980 KZ1000 LTD in very good condition with under 5K on the clock. It had been in a garage for 28 years so I took it to my garage and they switched the tires, lubed/replaced cables, spark plugs and cleaned the carbs ect. It runs pretty damn well now except the choke doesn't seem to do much and I have to warm her up by hand, which I don't really mind.
I just now noticed that one of the four headers are bluing, what does that mean on these bikes? My Triumph blued but they all seem to. Am I being too harsh on the old girl or are my carbs not as clean as I was lead to believe? Any other thoughts?
Cheers,
G
Cheers,
G
1980 KZ1000 LTD
- MFolks
- Thank you received: 540
16 Jun 2012 18:22 #529647
by MFolks
Replied by MFolks on topic Bluing on only one pipe?
Most if not all of the Japanese bikes had double wall exhaust pipes from the factory,now if your pipes are aftermarket they might be single wall showing the exhaust temperature conditions. I'd pull the sparkplugs and see how they're burning.checked the compression?
- RumbleFish
16 Jun 2012 18:35 #529651
by RumbleFish
1980 KZ1000 LTD
Replied by RumbleFish on topic Bluing on only one pipe?
Yeah I am pretty sure the pipes are stock, that is concerning. I will get the sparks out tonight and have a look at them.
Cheers
G
Cheers
G
1980 KZ1000 LTD
- Thank you received: 2829
16 Jun 2012 18:54 #529661
by 650ed
Replied by 650ed on topic Bluing on only one pipe?
If you have a stock pipe turning blue you really need to find the problem because that cylinder is running way too hot. Ed
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
17 Jun 2012 00:40 #529736
by andy9802gt
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Replied by andy9802gt on topic Bluing on only one pipe?
I'd suspect a cracked intake boot on that cylinder.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
