Oil drain plug stuck
- JMKZHI
Last edit: 03 Dec 2008 20:44 by JMKZHI.
- bountyhunter
Re: Oil drain plug stuck
14 Feb 2008 15:07
wireman wrote:
Unless you take out the spark plugs and use the kickstarter to pump the oil out. I have done that before, back when my headers completely blocked the pan drain plug: I had a fitting that went in the hole where the oil presure sensor is, which is right at the output of the pump. Using the kickstarter (and your arm), you can pump out about 95% of the oil. It will also pump dirty oil out the filter passage if the cover is off.
flht1997 wrote:you wont get all the oil out the filter hole.take the fill plug out and invert the bike? but seriously the filter should also be on the bottom of the motor, it will be messy but all the oil should come out there as well
- KZQ
- Administrator
14 Feb 2008 16:52
Hey Folks,
BeckyLynn Started this thread in June 06 and hasn't been back since. Even Wireman posted in this thread!
KZCSI
Post edited by: KZCSI, at: 2008/02/14 19:56
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- KTA
14 Feb 2008 22:14
Craftsman makes an amazing set of tools for this and it surprises me that more people aren't aware of them. They are a set of sockets with spiraled sharp edges on the inside. As you turn the socket it digs itself into the bolt head to grab on tighter and tigher. Every single rounded stuck bolt I have ever had in the last several years I have removed with this socket set. Run down to your local sears and have a look. They are much nicer than trying to use a giant wrench or heat. One of the best tools I have ever purchased!
Follow my
Evan Fell Cycles: Motorcycle Blog
evanfell.com | twitter.com/evanfell_cycles | flavors.me/evanfell
- NickW900LTD
- Nick
15 Feb 2008 01:07
KTA wrote:
I have used the same tool on a stripped bolts, they work awesome!!!
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- MSGAmling
- Its better to burn out than it is to rust
17 Feb 2008 09:24
While this will be of no value to the original poster, since I doubt she is following this thread anymore (and may not even have her KZ either), one idea for draining oil when the bolts can't be loosened, or are inaccessible, is a vacuum pump. This is availabe at any marine supply store.
This would not be my ideal solution for a motorcycle, but it worked well for me on several boats. The engine rooms/compartments are often too small to get down to the oil drain plug, and the oil must be suctioned out from the top. Getting a good vacuum worked up in the tank, then putting the small suction hose down into the crankcase and working it around will pick up a surprising amount of crud from the bottom, along with almost all the oil.
81 KZ650H CSR (Stock except WG Coil Mod and Air Injector elimination)
80 Yamaha DT125G Enduro
81 KZ440 Stock
76 Honda CR250M Elsinore - Sold
80 Honda XR200 - Sold
81 KZ440 Stock
- Bluemeanie
17 Feb 2008 09:35
BeckyLynn, being a mechanic I been in your spot many times. I finally bought a set of these Vice Grips in different sizes which are made just for our application. I've used them on many rounded off oil pan bolts and various other bolts and they have worked everytime!
