Oil drain plug stuck
08 Jun 2006 10:57 #52956 by BeckyLynn
Oil drain plug stuck was created by BeckyLynn
Hi there,
I can't seem to get my oil drain plug or the oil filter off of my bike. It's a 1974 KZ400. The bolt heads are stripped. I tried vice grips, but they just seemed to chew up the heads even more. I just bought the bike, so god only knows when the last time was that someone changed the oil (scary, huh?). Any suggestions on what I can do without buying any weird or special tools?
I have things like vice grips, big ol' adjustable wrench, socket set, rubber mallet, dremel, and your garden variety screwdrivers, wrenches, etc.
Thanks!
08 Jun 2006 11:01 #52960 by Wizzard
Replied by Wizzard on topic Oil drain plug stuck
Use a chizzel or flat screww driver and use it to make a slot in the side so you can hit the screwdriver and hit with a hammer hope I explaned it right.
Wizzard!!B)
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
08 Jun 2006 11:06 #52963 by OKC_Kent
Replied by OKC_Kent on topic Oil drain plug stuck
cHECK THIS LINK
kzrider.com/component/option,com_joomlab...atid,2/id,8361/#8361
Chisels not a bad idea. Buy a new bolt before you work on it.
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
  • wireman
  • Visitor
08 Jun 2006 11:11 #52967 by wireman
Replied by wireman on topic Oil drain plug stuck
pipewrench!:whistle:
08 Jun 2006 12:26 #52995 by BARNEYHYPHEN
Replied by BARNEYHYPHEN on topic Oil drain plug stuck
18" "Stilson" (Pipewrench) with a 4' gas pipe slotted over the handle. The pipewrench is designed to tighten harder and lock itself onto the bolt the more "pull" you put on it.
Obviously, if the wrench is coming out the righthand side of the bike, pull the wrench towards the back of the bike.
Good luck.
08 Jun 2006 15:47 #53041 by BeckyLynn
Replied by BeckyLynn on topic Oil drain plug stuck
A pipewrench is a good idea... never thought of that. Well, I'm still waiting to find out if my local parts supplier has a new oil plug for me, so as soon as I get the new part I'll start trying all of your ideas!
08 Jun 2006 15:51 #53042 by flht1997
Replied by flht1997 on topic Oil drain plug stuck
take the fill plug out and invert the bike? but seriously the filter should also be on the bottom of the motor, it will be messy but all the oil should come out there as well
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
08 Jun 2006 16:02 #53047 by BeckyLynn
I thought of taking the oil filter out and draining it that way... problem is, the oil filter bolt is stripped, too! I have to get both of the bolts off and replace them. It sucks. I seriously don't think the previous owner ever bothered to change the oil; there's about 20 years of dirt and grime on those bolts!
Inverting, eh? Creative! :)
08 Jun 2006 16:08 #53049 by Fossil
Replied by Fossil on topic Oil drain plug stuck
I couldn't get either the drain or fill plugs out of a JEEP transfer case. I ended up gently warming them up with a propane torch and they came out no problem. Might be worth a try.
  • wireman
  • Visitor
08 Jun 2006 17:59 #53061 by wireman
you wont get all the oil out the filter hole.;)
14 Feb 2008 14:44 #194624 by timmac59
Replied by timmac59 on topic Oil drain plug stuck
These drain plugs seize up all the time..I had the same problem... pipe wrench was definatly the best thing.. vice grips slipped,, bashed up knuckels.. and everything else wasnt strong enough...
14 Feb 2008 15:02 #194630 by bountyhunter
Replied by bountyhunter on topic Oil drain plug stuck
Use a hack saw or thin file to slot the head. Then get an impact screwdriver with a flat blade head and a hammer.
