Bike only runs on starter fluid
- phatman1969
15 Jun 2012 18:38
Hi again everyone. I put my 84 kz700 back together today and tried to fire her up. Wont start or run on anything but the starter fluid. It revs up on it then drops down and eventually quits. Guy I bought it from just "cleaned" the carbs. Anything else i should look at before i take the carbs apart again? I know I have spark, I know I have gas(at least the float bowls filled up) and I know there is air.Any help is appreciated.
- 4TheKZ1000
Re: Bike only runs on starter fluid
15 Jun 2012 20:36
are carbs getting gas. Ive seen floats installed backwords.
- trianglelaguna
15 Jun 2012 22:05
carb time...clean table and a few cans of parts spray...clean floor......camera.....all will be well
nice dish to hold small stuff
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
The following user(s) said Thank You: phatman1969
- 4TheKZ1000
15 Jun 2012 23:31
go to walmart and buy a gallon of bearymanns carb dip. break then down all rubber out and soak them for 12 hrs. when done, scrub them in hot water and dawn dish soap then rinse them very good and blow out with compressed air.I have done it with great sucess.
Attachment KawasakiCarbRebuild002.JPG not found
- wireman
15 Jun 2012 23:42My god those are the shiniest carbs Ive ever seen! :woohoo:4TheKZ1000 wrote: go to walmart and buy a gallon of bearymanns carb dip. break then down all rubber out and soak them for 12 hrs. when done, scrub them in hot water and dawn dish soap then rinse them very good and blow out with compressed air.I have done it with great sucess.
- 4TheKZ1000
- phatman1969
16 Jun 2012 00:19
Holy smokes those are clean. I already have the berrymans ready to go,will start on them tomorrow. Hopefully soon can get it running and get some pics.
- 4TheKZ1000
16 Jun 2012 12:33
dont do it in the house as your wife will be pissed due to the smell. Please wear solvent gloves during the process. Use a old tooth brush to clean strubren areas They wont be shinny like mine....I polished them....but they will be very clean inside and out, when done you can start with a clean proper set of carbs. Inspect all parts and replace as needed. The float needle and seat assembly should be looked at. Remember, old gas is the cause of most carb problems; use a gas stabilizer 100% of the time this will eliminate issue of bad gas. Good luck
- phatman1969
17 Jun 2012 17:30 - 17 Jun 2012 17:30
Ok, so I took the carbs out today and cleaned them. I have never owned a bike with 4 carbs on it so I was when I saw some extra inlets between two of the carbs. What i have is one fuel inlet in the middle that looks like it feed across 4 carbs, and then two more between the two side carbs. They clearly look like they dump fuel into the bowls. Am I correct? Once again i bought this bike incomplete and some stuff obviously is missing. Is there a some kind of a tee that comes from main fuel line to each inlet seperately? Thanks
Last edit: 17 Jun 2012 17:30 by phatman1969.
- 4TheKZ1000
17 Jun 2012 17:45
OK, do you know what carbs you have?
If not, you will need to post a few pics to the forum so e can id them.
there are fuel tees and just stright fuel couplings....
- phatman1969
17 Jun 2012 18:03 - 17 Jun 2012 18:05
they are the mikuni, i think the bs34. there is 1 fitting in the middle between the two inner carbs and then between each of the outer carbs a fitting. In the float bowl you can see where I think the fuel comes in. thanks
Last edit: 17 Jun 2012 18:05 by phatman1969.
- 4TheKZ1000
