Help-kz1000 head gasket replacement
  • vintkaw77
  • vintkaw77's Avatar Topic Author
15 Jun 2012 14:18
#529319
I wanted to replace the head gasket on my 77 kz1000. when I remove the head nuts and removed the head the cylinder gasket seeped oil but did not totally unseat. Do I need to take the cylinder head(having to reinstall pitstons)off as well and replace the base gasket or is there a chance it will reseal when I put the head back on?
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Help-kz1000 head gasket replacement
15 Jun 2012 14:29
#529321
Do you like to gamble ???
Do you feel Lucky ???
50/50 odds
I say replace it , but I like to error on the side of caution.
  • vintkaw77
15 Jun 2012 16:40
#529349
has anyone ever been lucky?
  • Moderator
  • Moderator
15 Jun 2012 17:01
#529353
If it wasnt for Luck I wouldnt be here to type this. LOL :laugh: :woohoo: :lol:
But I would still replace the base gasket B)
  • wireman
  • wireman's Avatar
15 Jun 2012 19:07
#529402
Street Fighter LTD wrote: If it wasnt for Luck I wouldnt be here to type this. LOL :laugh: :woohoo: :lol:
:laugh: :laugh: :laugh: :laugh: :laugh:
  • Samwell
  • Samwell's Avatar
16 Jun 2012 11:36
#529565
vintkaw77 wrote: I wanted to replace the head gasket on my 77 kz1000. when I remove the head nuts and removed the head the cylinder gasket seeped oil but did not totally unseat. Do I need to take the cylinder head(having to reinstall pitstons)off as well and replace the base gasket or is there a chance it will reseal when I put the head back on?
I've gotten away with it on an old Honda CB650. My mechanic at the time told me if its not disturbed at all then you're usually (75-80%) okay. If you think its disturbed at all, change and save the grief....
Sam
  • RonKZ650
  • RonKZ650's Avatar
16 Jun 2012 11:54
#529568
Just remember if you remove the cylinder, the rings will never seat again, so you'll need new rings and a hone. I'd rather have a small oil leak than go though putting the base gasket on and all the grief and money.
  • wireman
  • wireman's Avatar
16 Jun 2012 13:10
#529580
its a good excuse to check/fix all those other things while youre in there.
Its been my experiance anytime you replace a head gasket or do a valve job on a questionable motor that shortly there after lose rings will rear their ugly heads,so why not just check things since youre in there? B)
The following user(s) said Thank You: geroom
  • mtkawboy
  • mtkawboy's Avatar
16 Jun 2012 14:29
#529599
If it hadnt seeped Id go for it but since it did you better change it. If you leave then undisturbed they will be OK
  • vintkaw77
16 Jun 2012 18:16
#529645
Even though this 1075 cc bored out motor only has less than a thousand miles on it, the piston rings wont re-seat? Why it has a leak just bad luck when the builder installed the gasket. So now im going to do it! Let me know what u think.
  • APE Jay
  • APE Jay's Avatar
16 Jun 2012 20:24
#529688
Does it have heavy duty studs?
  • vintkaw77
16 Jun 2012 21:30
#529696
yes
