'80 KZ750E1 - Engine sounds like V8
  • -[DawG]-
  • -[DawG]-'s Avatar Topic Author
15 Jun 2012 09:57 - 15 Jun 2012 10:11
#529274
Hey guys,
Hope the subject is not too confusing, I'm finding it difficult to put my problem into a specific, 1 line term, thus searching for it rendered no results.
After a lot of small and minor problems, we eventually fired up the old lady after about 4 years. But the problem is that the bike is not idling, not picking up revs, and it sounds like its running on 2 cylinders.
The coils, spark plugs, CDI, Cam Timing and Ignition timing (hopefully) are all in order.
According the the exhaust, cylinders #1 and #2 heats up very nice, #3 is a little colder than #1 & #2, and #4 is about 60% of #1 and #2. The bike does not struggle to start, but the way the engine is running is WAY off.
I cant explain the problem anymore than this, thus, I attached 2 sound clips of the starting process for someone to perhaps give their opinion on. Apologies for the echo, we are working in a small garage with the phone miles away.
If anyone can identify the sound or have experienced a bike sounding like this, kindly share your thoughts. Anything will be helpful.
Thank you all in advance :)
Attachment FirstStart.zip not found
Attachment SecondStart.zip not found
EDIT: If anyone is skeptical about the zip files, please let me know and I'll post some VirusTotal reports.
"Everything has beauty, but not everyone sees it."
1982 KZ750R - Sold
1980 CX500 - Sold
1980 KZ750-E1 - Project
GSXR1100 SS - Future Project
2000 CBR600F4 - Sold
2008 DRZ400SM - Sold (Biggest mistake EVER)
2007 KTM 200 XCW - Smokin Toy :D
Last edit: 15 Jun 2012 10:11 by -[DawG]-.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: '80 KZ750E1 - Engine sounds like V8
15 Jun 2012 10:43
#529282
Need more info , but check plug wires on right cylinders
  • faffi
  • faffi's Avatar
15 Jun 2012 10:47
#529285
Clogged idle jet circuits in the carbs is likely after 4 years. You could try Seafoam and strike luck, meaning you could save yourself a carb strip.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
  • loudhvx
  • loudhvx's Avatar
15 Jun 2012 10:53 - 15 Jun 2012 10:55
#529287
MP3's worked fine for me.
Wow. You're right, it does have that uneven rumble of a v8 with dual exhausts.
To me it sounds like it's missing on one cyclinder, but possible the other cylinders are firing at very uneven power levels.
I would start at the beginning with a compression test.
If that's all good, then I'd check for spark on all four plugs, one at a time and make sure each one, individually can get a 1/4 inch spark. Don't go over a 1/2 inch gap as that will stress the coils and ignition. At idle, you don't need a lot of spark voltage.
If that's all good, then I'd start checking the idle circuits in the carbs. EDIT: Faffi beat me to it.
Last edit: 15 Jun 2012 10:55 by loudhvx.
  • Motor Head
  • Motor Head's Avatar
15 Jun 2012 16:02
#529339
Anybody want to open then re-post these zip files so they will play for everyone?
  • loudhvx
  • loudhvx's Avatar
15 Jun 2012 20:15 - 15 Jun 2012 20:25
#529423
These will be temporary:
First Start.mp3
Second Start.mp3
Last edit: 15 Jun 2012 20:25 by loudhvx.
15 Jun 2012 23:00
#529460
You need to correct the title of this thread. It should say "Engine sounds like a Ford V8." :laugh:
  • Motor Head
17 Jun 2012 01:49
#529766
Do you have the spark plug wires on right? Getting spark to all 4? If so next would be to check compression. If compression is good, spark good, then probably fuel.
  • -[DawG]-
20 Jun 2012 06:22
#530479
Hey guys,
Thanks for all your help. We cleaned out the carbs and voila! Its running lekker :)
I dont know if I should start a new thread about it, but we are struggling with the pilot system (not running as smooth as on higher rev's) and a rich mixture with some sooty deposits on one plug.
All your help is appreciated :)
1982 KZ750R - Sold
1980 CX500 - Sold
  • Nebr_Rex
  • Nebr_Rex's Avatar
20 Jun 2012 20:47 - 20 Jun 2012 20:49
#530596
650ed wrote: You need to correct the title of this thread. It should say "Engine sounds like a chevy V8." :laugh:
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Last edit: 20 Jun 2012 20:49 by Nebr_Rex.
