Oil Problem?
- tbaumga2
14 Jun 2012 22:43 #529197
by tbaumga2
Oil Problem? was created by tbaumga2
I've got a 81 GPZ500 that I know leaks oil, and it's fine if I keep it topped up. I'm unsure, however, when it's getting low.
When the bike is on its center stand, the oil window appears full. But when I put it on its side stand, the window empties. So I'm not sure which one I should go by.
Anyone else have experience with this?
- 4TheKZ1000
- Visitor
14 Jun 2012 22:54 #529199
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Oil Problem?
center stand hence center. side stand hence on the side. you will have a better reading on a flat surface center stand. just hold the grip standing to the side and center the bike looking at the level of oil.
- Thank you received: 1656
15 Jun 2012 09:44 - 22 Jan 2013 19:58 #529273
by martin_csr
Last edit: 22 Jan 2013 19:58 by martin_csr.
- tbaumga2
15 Jun 2012 18:56 #529394
by tbaumga2
Replied by tbaumga2 on topic Oil Problem?
that's what I thought as well. thanks!
and have changed it - last time about 600 miles ago
