what are these for?
- xbmxxx
12 Jun 2012 23:53 #528691
by xbmxxx
I am assuming they are just breathers, or possibly a pcv system that hooked in to the factory airbox, and I was planning on capping them off. Just making sure they dont actually need to be connected to anything and I'm not going to hurt it.
76 KZ750B Twin
what are these for? was created by xbmxxx
76 KZ750B Twin
- marla_do
13 Jun 2012 00:10 - 13 Jun 2012 00:11 #528697
by marla_do
Replied by marla_do on topic what are these for?
are they reed-valves?
something to do with emissions on certain years (aka. annoyance)
don't have them on my canadian 650 but i've heard others complain about them
Last edit: 13 Jun 2012 00:11 by marla_do.
- xbmxxx
13 Jun 2012 00:22 #528701
by xbmxxx
76 KZ750B Twin
Replied by xbmxxx on topic what are these for?
Yeah, my 76 B twin does not have them, but my 80G does, which is why I think I can get away with just capping them off
76 KZ750B Twin
- steell
13 Jun 2012 00:43 #528710
by steell
Replied by steell on topic what are these for?
You can hook them together with a hose or just cap them off. They feed fresh air from the air box into the exhaust ports via two small passages. You can block off those passages with epoxy and use an early model cam cover, that's what I did to the 82 motor in my 79 750B.
Far as I know the 80 750G didn't have those, except maybe a California model.
- Thank you received: 2098
13 Jun 2012 01:11 - 13 Jun 2012 01:14 #528721
by Patton
Replied by Patton on topic what are these for?
May cap each of them, or connect them together.
Above is applicable to four cylinder models, but believed also applicable to the KZ750 twin.
Last edit: 13 Jun 2012 01:14 by Patton.
- xbmxxx
13 Jun 2012 01:44 #528738
by xbmxxx
76 KZ750B Twin
I should clarify, the frame is an 80g, no clue if the engine is out of that frame or not.
Awesome! I really appreciate all the help!
76 KZ750B Twin
- roy-b-boy-b
- Thank you received: 103
13 Jun 2012 04:48 #528761
by roy-b-boy-b
Replied by roy-b-boy-b on topic what are these for?
- steell
13 Jun 2012 14:10 #528849
by steell
Probably not, since that is a 4 cylinder 1000 and his is a two cylinder 750
roy-b-boy-b wrote: Does your engine serial number fall in this range?
www.zedder.com/Info/80%20KZ1000-G1%20Classic.htm
- roy-b-boy-b
13 Jun 2012 14:42 #528855
by roy-b-boy-b
:sick:
As we use to say in the old days,"That's Weak" !
