- Thank you received: 2
kz 1000 ltd clutch 1982
- spark23ca
12 Jun 2012 02:07 #528411
by spark23ca
1982 kz 1000 ltd ..someone started to make a bobber out of it and realized it didnt' run and they didn't know how to run their wrenches
kz 1000 ltd clutch 1982 was created by spark23ca
i bought this old basket case ..trying to fix it up ..took it on its mayden voyage today...ran bad but still haven't cleaned the carbs or cleaned oiled or even looked at the timing advance ..BUT i have the clutch will not disengage ..i've set up the cables to the max...stll nothing ...when idleing if in neutral and u put in first it stalls right out ..unless u get a rolling start?? just wondering if anyone else has had this problem
- Thank you received: 2098
12 Jun 2012 07:25 - 12 Jun 2012 07:26 #528427
by Patton
Replied by Patton on topic kz 1000 ltd clutch 1982
Should probably add "clutch push-rod adjustment" to the to-do list.spark23ca wrote: i bought this old basket case ..trying to fix it up ..took it on its mayden voyage today...ran bad but still haven't cleaned the carbs or cleaned oiled or even looked at the timing advance ..BUT i have the clutch will not disengage ..i've set up the cables to the max...stll nothing ...when idleing if in neutral and u put in first it stalls right out ..unless u get a rolling start?? just wondering if anyone else has had this problem
Last edit: 12 Jun 2012 07:26 by Patton.
