- Thank you received: 4
sealant on top end gaskets?
- richrand
11 Jun 2012 20:42 #528290
by richrand
sealant on top end gaskets? was created by richrand
I'm getting ready to reassemble my top end (block, head, valve cover) and the oil pan. All surfaces are clean, but not milled. I'm very certain that this is the first time the head and block have been off.
Should a sealant (such as copper spray) be used on the base or head gaskets? I'd really like to ensure that they will be sound. Stuff I've read online ranges from "definitely" to "don't even think about it." Any help would be appreciated. I want to do this right.
- racer54
- Thank you received: 114
11 Jun 2012 21:42 #528306
by racer54
Replied by racer54 on topic sealant on top end gaskets?
What kind of gaskets do you have? Paper or copper?
- richrand
11 Jun 2012 22:29 #528321
by richrand
Replied by richrand on topic sealant on top end gaskets?
I got the full set from Z1 Enterprises. Basically this:
www.z1enterprises.com/Gasket-Set--KZ1000...e--Full-Set-467.aspx
They seem to be all paper?
- wireman
- Thank you received: 299
11 Jun 2012 23:01 #528333
by wireman
Replied by wireman on topic sealant on top end gaskets?
I use aerosol copper coat on all gaskets except fiber/steel head gaskets
- zukdave
- Thank you received: 229
11 Jun 2012 23:29 #528354
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic sealant on top end gaskets?
I tend to put most paper gasket's on dry
and seem to have good luck that way.
Copper coat works great on a Brigg's
head gasket if we don't have one in stock
at work.
at work.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- wireman
12 Jun 2012 00:32 #528387
by wireman
:laugh: :laugh: :laugh: :laugh: :laugh:
- bountyhunter
- Thank you received: 337
12 Jun 2012 01:03 #528395
by bountyhunter
Replied by bountyhunter on topic sealant on top end gaskets?
I would use something good like 3-bond on the base gasket because it should not be coming off for a long time.
Shouldn't need sealer on the head gasket.
I use the Ultra Black Hi Temp on the valve cover because they like to leak over the cam end plugs.
