- Thank you received: 16
Cam Chain and Tensioner
- Drooz
11 Jun 2012 19:53 #528272
by Drooz
'77 kz1000 (zx10r) Modified/Street
'81 GPz550 "TrackBike"
'05 zx10r Retro/Mod Sportbike 4 SALE!!
'02 zrx1200r Lightly Modified Street SOLD!!
'74 h2b 750 (FZ600) "Mongrel" 2 Stroke SOLD!!
"Invictus Maneo" - I remain unvanquished.
Kawasaki - Let The Good Times Roll!
Mississauga, Ontario. CANADA
Cam Chain and Tensioner was created by Drooz
I'm looking to replace the cam chain and tensioner on my '77 kz1000. Is there anything else I should consider at this time and where can I find all the parts needed?
Any other advise would be appreciated!
- Drooz
11 Jun 2012 19:54 #528273
by Drooz
Replied by Drooz on topic Cam Chain and Tensioner
The engine is internally stock. That may be changing soon, but for now...
- Motor Head
- Thank you received: 391
11 Jun 2012 19:55 #528274
by Motor Head
Replied by Motor Head on topic Cam Chain and Tensioner
APE has a replacement that is mechanical adjustment, not automatic. Less chance of problems.
- LarryC
11 Jun 2012 21:04 - 11 Jun 2012 21:07 #528296
by LarryC
Why replace a perfectly good manual tensioner with a more expensive after market manual tensioner? If you have run out of travel with the plunger, the cam chain and probably all the idlers needs replaced, not the tensioner.
If it was a J motor, it would be a different story. Not a KZ with a peanut or even a "so called" heavy duty chain.
Larry C.
Replied by LarryC on topic Cam Chain and Tensioner
Motor Head wrote: APE has a replacement that is mechanical adjustment, not automatic. Less chance of problems.
Larry C.
Last edit: 11 Jun 2012 21:07 by LarryC.
- pete greek1
- Thank you received: 185
11 Jun 2012 21:49 #528308
by pete greek1
Replied by pete greek1 on topic Cam Chain and Tensioner
Larry...sending a P.M. shortly.. I.dont type too fast
