'79 KZ1000 ltd smoke on start up
  • xxsierraxx
  • xxsierraxx's Avatar Topic Author
11 Jun 2012 11:51
#528151
Hi there, just wanting to get some ideas concerning my bike smoking on start up. It's a '79 ltd which will smoke out left bank at start up for about 3-4 mins and then will clear up. It only burns about .75 lt per 1000 km's which from what i read is okay. I have replaced the head with a very low mileage head, with new seals, gaskets etc. Guides are in good shape. This year I pulled head again and replaced seals with better seals thinking I may have installed incorrectly. Same problem exists. Heres the strange part (to me at least). If i park my bike leaned to the right hand side it doesn't smoke at start up, or if it does, very little. I can't imagine that 2 different heads, laek at same cyclinder for same amount. Any ideas?
1979 KZ1000
1981 CSR 650
Honda "cough"
  • LarryC
  • LarryC's Avatar
Re: '79 KZ1000 ltd smoke on start up
11 Jun 2012 16:08 - 11 Jun 2012 16:13
#528201
.75 liters is .8 quarts
1000 km is 620 miles
That's above normal for oil consumption if the bike doesn't leak any oil.
Larry C.
Last edit: 11 Jun 2012 16:13 by LarryC.
  • xxsierraxx
11 Jun 2012 16:37
#528205
I believe .75 lt (and its a rough guess) is about .7 of a qrt. Which is roughly burning 1.12 qrt per 1000 miles. According to what I have read that isn't that big a deal.
1979 KZ1000
1981 CSR 650
Honda "cough"
  • xxsierraxx
11 Jun 2012 20:17
#528280
Actually you're right, my math is backwards, I might have overestimated the oil consumption though. Not as bad as i had mentioned.
1979 KZ1000
1981 CSR 650
Honda "cough"
  • spark23ca
  • spark23ca's Avatar
12 Jun 2012 02:03
#528410
smoke on start up is usually bad valve seals ...find a long hill and get going a little fast b4 the hill then let er coast to the bottom...then give it a shot of gas..if it smokes then its your valve seals...when the butterfly's are closed on any engine it creates a vacuum witch will suck oil threw bad seals..bad valve seals will foul up a plug now and then ...and u got to keep an eye on your oil level other then that drive er ..won't hurt a thing
1982 kz 1000 ltd ..someone started to make a bobber out of it and realized it didnt' run and they didn't know how to run their wrenches
  • xxsierraxx
12 Jun 2012 10:13
#528465
I don't get a puff at the botom on deceleration, anyone riding behind me says its okay that way. I just can't imagine, 2nd head, 3rd set of valve seals still smoke in same cylinder. yesterday after parking with bike leaned to right for couple days, no smoke at all.
1979 KZ1000
1981 CSR 650
Honda "cough"
  • trianglelaguna
  • trianglelaguna's Avatar
12 Jun 2012 11:55
#528499
these bikes smoke on start up i tiny bit imo even good ones
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • wireman
  • wireman's Avatar
12 Jun 2012 14:24
#528537
xxsierraxx wrote: I don't get a puff at the botom on deceleration, anyone riding behind me says its okay that way. I just can't imagine, 2nd head, 3rd set of valve seals still smoke in same cylinder. yesterday after parking with bike leaned to right for couple days, no smoke at all.
when it sits on the kickstand oil in top of motor is going to settle around the #1 valve and spring,its just gravity.
Try parking it on center stand if you have one B)
  • xxsierraxx
12 Jun 2012 21:06
#528620
I don't park on kickstand anymore because of that, I park it leaned to the right with a block under right side crash bar.
1979 KZ1000
1981 CSR 650
Honda "cough"
  • lemo32
  • lemo32's Avatar
  • The Price of Cool aint cheap
12 Jun 2012 21:23
#528622
Depending on color of smoke might not be oil at all, could be fuel, leaky carb or petcock?
1979 kz 1000 06 katana 750
  • xxsierraxx
13 Jun 2012 10:41
#528807
It's blue, new carbs as well with float height adjusted. Petcock rebuilt and I turn fuel valve off hen not used.
1979 KZ1000
1981 CSR 650
Honda "cough"
  • Motor Head
  • Motor Head's Avatar
13 Jun 2012 10:48
#528809
If as you think, it is from oil dripping down the Valve guides do to faulty seals or loose guides. Then take the Carb, and the Exhaust off. then park it over to the left and look for fresh oil in the ports. You could apply up to 4 psi to the crankcase to aid in this diagnosis. must be a regulated low air pressure.
