Too much oil
- raulfd4
11 Jun 2012 11:09 #528143
by raulfd4
1980 Kawasaki KZ440A
Too much oil was created by raulfd4
I just did an oil and filter change on my 1980 KZ440. The Clymer manual said to add 3.1 quarts of oil with the new filter. When I first started the bike there was a fair amount of smoke and after riding it around for about 15-20 miles, I noticed that there was some oil leaking from the right side of the engine (along the gaskets on the bottom of the clutch cover and I think a bit from up near the cylinder gaskets (?))
When I saw this I checked the oil level and it indicates that there is too much oil. I plan on taking some out this afternoon. Two questions:
1) What is the best method to remove oil and make sure you haven't taken out too much? I was thinking about just putting it up on the center stand, pulling the oil drain plug, and keeping an eye on the oil level window until it reached the right spot. Otherwise it seems like it will be a messy trial-and-error type of job.
2) I'm afraid I may have compromised those seals/gaskets by riding around with too much oil. Do you think they are permanently damaged, or once the oil pressure goes down after taking some oil out, I should be okay?
- Motor Head
- Thank you received: 391
11 Jun 2012 11:12 #528144
by Motor Head
Replied by Motor Head on topic Too much oil
Drain some out via the drain plug and get it to just above center of the sight glass when on the center stand. Then clean up the leaking area, and take it for a ride. See if it leaks. If so then you will have to repair those seals/ gaskets that are leaking.
- Thank you received: 2829
11 Jun 2012 11:42 #528149
by 650ed
Replied by 650ed on topic Too much oil
Stick a piece of clear plastic tubing in the filler hole and siphon some out.
- loudhvx
- Thank you received: 1616
11 Jun 2012 13:44 #528177
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Too much oil
You can get something like this at most drug stores. I get mine dirt cheap at American Science and Surplus. Very handy to have a few of them around.
1981 KZ550 D1 gpz.
Other links.
- mtkawboy
11 Jun 2012 17:37 #528219
by mtkawboy
Replied by mtkawboy on topic Too much oil
Do your checking with the oil hot too
