strange rattling ONLY when closing throttle
- FKK
10 Jun 2012 14:05 #527963
by FKK
strange rattling ONLY when closing throttle was created by FKK
Hello,
My name is Felix from Holland. I have a 1982 KZ750R1.
It has always run well but now I have this strange rattling noise that only occurs when I close the throttle. In idle you hear nothing. Also when accelerating or cruising this noise does not occur.
I have no clue what that may be. Anyone?
thanks in Advance
Felix
thanks in Advance
Felix
- Thank you received: 2098
10 Jun 2012 14:43 #527968
by Patton
Replied by Patton on topic strange rattling ONLY when closing throttle
Wild guess -- Muffler name plate is loose.
- Kraz1
10 Jun 2012 15:15 - 10 Jun 2012 15:15 #527982
by Kraz1
Replied by Kraz1 on topic strange rattling ONLY when closing throttle
I would have a look at the Cam Chain Tensioner... Check them, but a muffler plate or guard would tend to rattle under load or on the side stand as well.
Last edit: 10 Jun 2012 15:15 by Kraz1.
The following user(s) said Thank You: FKK
10 Jun 2012 15:19 #527984
by Patton
Would also check the drive chain for possible kinks, any (slack) adjustment needed, any lube needed.
10 Jun 2012 15:22 - 10 Jun 2012 15:36 #527987
by Patton
When at idle in neutral, and revved, is the same rattle heard as the rpm drops back to idle?
In other words, can the rattle be duplicated with the engine running in neutral?
If so, this may make it easier to locate the source of the rattle.
Last edit: 10 Jun 2012 15:36 by Patton.
- Kraz1
10 Jun 2012 15:27 #527989
by Kraz1
Just hang in there... General Patton is going to show you how to Download the Service Manual..
Good Fortune ! ! :blink:
- FKK
10 Jun 2012 18:41 #528013
by FKK
Replied by FKK on topic strange rattling ONLY when closing throttle
No, the rattle is only under load.
I am quite convinced it is coming from out of the engine , not external parts such as muffler plates...
- APE Jay
- Banned
- Thank you received: 58
10 Jun 2012 19:38 #528021
by APE Jay
Replied by APE Jay on topic strange rattling ONLY when closing throttle
Sounds like the can chain tensioner is backing out then snapping shut. That is the reason people use the manual tensioners.
