Oil Pressure at Idle on KZ1000
08 Jun 2012 20:06 #527710 by 2wheeltom77
Oil Pressure at Idle on KZ1000 was created by 2wheeltom77
Quick question on oil pressure. I have a gauge on my 79 KZ1000. When I'd start it the pressure was always a little above 2 and would hit about 8 or so when I revved it. After a ride today I noticed the pressure sitting at 0 at idle, and went up to 3 when I revved it. The manual says 2.8 at 3000 rpm, which was a relief, but is 0 at idle normal?
1979 KZ1000 one off
1982 Honda CX500 (sold)
2008 FXSTC
  • 4TheKZ1000
  • Visitor
08 Jun 2012 21:16 #527714 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Oil Pressure at Idle on KZ1000
6 to 9
  • gearheadmm
  • MUCH MORE BOOST..........I mean BRAVO
08 Jun 2012 21:33 #527716 by gearheadmm
Replied by gearheadmm on topic Oil Pressure at Idle on KZ1000
Make sure your gauge is correct by checking it against a known good gauge. Vibration will kill ANY gauge eventually.
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
08 Jun 2012 21:50 #527720 by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic Oil Pressure at Idle on KZ1000
Where is your gauge's oil line attached to the engine?
08 Jun 2012 22:52 #527736 by 2wheeltom77
Replied by 2wheeltom77 on topic Oil Pressure at Idle on KZ1000
It's a VDO gauge right on the oil galley plug. I just installed the gauge recently. This is a project bike I am building, motor has 40K on it. This is my first 4 cyl bike so I'm still getting familiar with the norms. I've put maybe 30 miles on it since I got the bike road worthy, and seems to run pretty good. Thanks for the replies.
1979 KZ1000 one off
2008 FXSTC
  • Motor Head
08 Jun 2012 22:55 #527737 by Motor Head
Replied by Motor Head on topic Oil Pressure at Idle on KZ1000
Oil choice can play on this, what are you running? Stay away from the 5-30w car stuff. Get a 15-40w or 20-50w, Rottela or Delo etc.
09 Jun 2012 00:20 #527762 by Patton
Replied by Patton on topic Oil Pressure at Idle on KZ1000
2wheeltom77 wrote: Quick question on oil pressure. I have a gauge on my 79 KZ1000. When I'd start it the pressure was always a little above 2 and would hit about 8 or so when I revved it. After a ride today I noticed the pressure sitting at 0 at idle, and went up to 3 when I revved it. The manual says 2.8 at 3000 rpm, which was a relief, but is 0 at idle normal?
Is the oil pressure dash light functional?
And if so, does it stay off at idle?
Good Fortune! :)
09 Jun 2012 09:01 #527797 by 2wheeltom77
I completely rewired this bike to basics, no dash lights. Am running 10w-40 Val bike oil. I do have idle set a little above 1000 and am thinking maybe I need to bump it up. I sort of forgot twincam harleys are the same way, don't make any pressure if idle is set too low. With this kaw motor, it seems like the only problem areas would have to be from the pump itself, or possibly really worn cam bearings.
1979 KZ1000 one off
2008 FXSTC
09 Jun 2012 09:23 #527801 by Patton
If the oil pressure switch is in position, and potentially functional although not wired into the bike's electrical circuitry, may use an ohmmeter to determine whether the oil pressure switch is being activated by oil pressure at idle rpm, regardless of whether the oil pressure switch is connected to any wires.
Knowing there's activation of the oil pressure switch at idle rpm would indicate at least some oil pressure .
Good Fortune! :)
09 Jun 2012 10:08 #527803 by 2wheeltom77
Patton wrote: If the oil pressure switch is in position, and potentially functional although not wired into the bike's electrical circuitry, may use an ohmmeter to determine whether the oil pressure switch is being activated by oil pressure at idle rpm, regardless of whether the oil pressure switch is connected to any wires.
Good Fortune! :)
You know what, that's a damn good idea. I'll give that a shot. Do you happen to know what psi the switch opens/closes?
1979 KZ1000 one off
2008 FXSTC
09 Jun 2012 11:54 #527817 by DiamondSkyBlue1000
Don't think anyone has mentioned this yet but bear in mind that the KZ engine does not have journal type crank bearings, it has roller bearings. Making a lot of oil pressure at low RPM's is not crucial. Getting a pressure reading denotes flow through the engine.
09 Jun 2012 12:12 #527820 by 2wheeltom77
DiamondSkyBlue1000 wrote: Don't think anyone has mentioned this yet but bear in mind that the KZ engine does not have journal type crank bearings, it has roller bearings. Making a lot of oil pressure at low RPM's is not crucial. Getting a pressure reading denotes flow through the engine.
Yeah, and that was my thinking that the worn out cam bearings would be the only wear component that might cause low pressure, and that's a maybe based on my understanding of oil flow through the engine.
I took about a 30 mile ride this morning. Started out cruising at about 5 psi, then warmed up about 2.5 to 3 at 3000 rpm cruising. By the time I got home pressure was about 2 at 3000, but went up to 3 about 3700 rpm.
I let the motor cool off to about 120 degrees and firing it up. Needle bounced a little at idle and read 3 at 3000.
At this point I'm thinking either the pump is a little worn, or worst case something starting to clog the screen up. If it gets worse after a few more rides, I'll change the oil and filter again. Then I guess it's time to pull the pump.
1979 KZ1000 one off
2008 FXSTC
