KZ550 with a CB750 Engine?
- PorkChop Express
Please help.
- DoubleDub
- Visitor
PorkChop Express wrote: So I've got a 1980 KZ550 with a frozen engine, and a bead on a cheap, working 1981 CB750 engine. Has anyone heard of a successful engine transplant of this caliber? Would you expect a lot of mounting issues?
Please help.
It's a whole new mounting system in a new frame. Expect to have to do everything custom.
- testarossa
- Thank you received: 82
Please help.
One of the main problems will be a packaging issue. Those twin cam Honda 750 cylinders tilt forward quite a bit compared to a KZ550. The geometry of the frame will be a challenge. Not to mention that the Honda motor is quite large in almost every direction. The motor in my 82 CB750F is larger in every way than my 78 KZ1000 motor.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- elfmagic17
- Thank you received: 24
testarossa wrote:
Please help.
+1 The cb750 is comparable in size to a kz1000 vs a kz550/650 small block to big block.cb550 is their biggest small block.
Kenny Hicks
74 Honda CB550
- baldy110
- Thank you received: 512
- floivanus
- Thank you received: 116
Past; 78 kz1000, 83 kz550
Andrew
