engine temp
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
engine temp
07 Jun 2012 21:23
#527549
anyone know how hot a kz1000 1075 cylinder will get during normal summer operation at temps 70 - 95 outside.
thanks, spence
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: engine temp
07 Jun 2012 22:24
#527562
VERY HOT. :P
my 1200cc kz sees 230* at 70F without an oil cooler.
OMR has some data on a 1075.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • BohicaBob
  • BohicaBob's Avatar
Re: engine temp
08 Jun 2012 10:19
#527627
My '73 Z1-900 (10.5 - 1 pistons, mild cams, pipe, Mikuni 29 smoothbores, etc.) will easily see 220+ degrees F oil temps without bike movement. One time oil temp hit 255 degrees F during a massive 10 mile traffic jam on a nearby interstate (I got off the interstate to cool the engine off, then took surface streets home). During Bike Week in Daytona, friends and I were stuck in traffic and oil temp hit 225 degrees in 46 degree air temperature on the beach. Once moving however, oil temps drop to 180 in a few minutes.
By the way, this bike has big oil cooler. Using 10W-40 AMSOIL MC oil dropped oil temp about 10-15 degrees, so I dropped running 20W-50 oils some time ago as a result.
Rigging up a thermostatic-controlled fan for the oil cooler or the cylinder block/head would really help during periods when the bike is not moving in air temps are high ... or low.
  • TexasKZ
  • TexasKZ's Avatar
Re: engine temp
08 Jun 2012 15:08
#527661
stole this from OMR's post
