How my boost can a stock kz750EE handle?
- adam90xj
06 Jun 2012 23:29 #527357
by adam90xj
How my boost can a stock kz750EE handle? was created by adam90xj
So this isn't some off the wall question. I have done quite a bit of research as to what it will take to boost my kz750. I have been building a megasquirt controlled boosted 78'280z but I'll be running a blow through carb setup on the bike simply for bang-4-buck. I have a couple turbos laying around my shop which are small enough to work on the bike. In fact, I have the t3 from the Zcar. I know these engines are pretty darn bullet proof but how much can I boost and still be reliable?
thanks for you thoughts,
Adam
Adam
- Nebr_Rex
- Thank you received: 300
07 Jun 2012 01:13 #527378
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic How my boost can a stock kz750EE handle?
What model is an EE?
If you have done your research you would know about the most sucessfull factory Turbo bike on the planet.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- wireman
- Thank you received: 299
07 Jun 2012 01:47 #527391
by wireman
Replied by wireman on topic How my boost can a stock kz750EE handle?
All the boost you can throw at it,till it breaks! :woohoo:
- adam90xj
07 Jun 2012 14:37 #527486
by adam90xj
Replied by adam90xj on topic How my boost can a stock kz750EE handle?
EE= E2 = 81' Kz750. I understand that the gpz is a very capable boosted engine which I'm sure runs a lower CR than my NA 750. Of the information I've found it looks as if 3psi-ish is about max on these NA engines..... I know I could boost it upwards of 20psi for a couple seconds/mins/etc but destroying an engine isn't my goal.
- Thank you received: 2829
07 Jun 2012 16:30 #527500
by 650ed
Replied by 650ed on topic How my boost can a stock kz750EE handle?
"EE= E2 = 81' Kz750"
I like it! So a KZ1000PPPPPPPPPPPPPPPPPPPPPPPP = 2005 KZ1000-P24 Police 1000. :woohoo: :laugh: :laugh:
- JR
- Thank you received: 448
07 Jun 2012 23:08 #527571
by JR
Replied by JR on topic How my boost can a stock kz750EE handle?
Lorcan would probably be the best person to answer those questions.
www.750turbo.com/home.htm
I hanv'nt seen him here for a while.
- 0Z.Z1R Mk2
- Thank you received: 31
08 Jun 2012 07:16 #527608
by 0Z.Z1R Mk2
Replied by 0Z.Z1R Mk2 on topic How my boost can a stock kz750EE handle?
I run 13psi on my 750turbo.
- adam90xj
08 Jun 2012 17:00 #527669
by adam90xj
^^^ What CR are you at?
- DFIGPZ
- Thank you received: 122
08 Jun 2012 18:55 #527695
by DFIGPZ
1984 750 Turbo
Replied by DFIGPZ on topic How my boost can a stock kz750EE handle?
why not install 750 turbo componets ? i would say on a stock KZ750 engine 8psi max on good pump gas i used to run 15psi on my 750 turbo with 93 octane gas but it was tuned well with race gas i ran it to 22psi but it would surge to 24psi till the waste gate opened.
1984 750 Turbo
