kz1000j turbo and FI question
- kz1000SF
06 Jun 2012 11:40 #527222
by kz1000SF
KZ1000SF = Stupid Fast
kz1000j turbo and FI question was created by kz1000SF
I have a 82 KZ1000j as my project bike. I want to see what it would take to run a turbo. I know you can buy turbo kits but I have fun welding and fabing my own gear. Can you run a turbo on a stock motor? I don't want to drag this bike I just want about 30 extra HP or so for street. I also would like to know who has done a fuel injection upgrade on these bikes and if that would work with a turbo or is there another carb to use instead. (I don't mind having to use a microsquirt or something) thanks! Any input helps.
- T_Dub
- Thank you received: 25
06 Jun 2012 11:50 #527223
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic kz1000j turbo and FI question
FI would actually be best for a turbo bike. You could use the throttle bodies from a GPz1100. I think you might have to upgrade injectors though.
I would get some low comp pistons in order to run a turbo, although the stock compression ratio is low enough to run under 10psi I would think.
I'd say go ahead, fab up your gear, get a set of GPz1100 throttle bodies, and use the stock engine with around 8psi of boost. Get an oil cooler to go with that.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- kz1000SF
06 Jun 2012 12:52 #527244
by kz1000SF
Replied by kz1000SF on topic kz1000j turbo and FI question
Awesome! That's what I needed to know! What would i have to do to make the gpz throttle bodies to work?
- Thank you received: 2065
06 Jun 2012 13:54 #527250
by Street Fighter LTD
Good Luck. Dont run to much boost on stock parts
Heres some pictures I found of a nice one off fab job turbo blowing thru what looks like injectors
Replied by Street Fighter LTD on topic kz1000j turbo and FI question
06 Jun 2012 13:56 #527251
maybe not injectors, but same basic design
- MFolks
- Thank you received: 540
06 Jun 2012 13:58 #527252
by MFolks
Replied by MFolks on topic kz1000j turbo and FI question
I'd look at geting the 1982 or later injectors, as the 1981's tended to heat soak due to design problems.
Fuel Injection
www.msefi.com
Fuel injection cleaning/calibration services
www.witchhunter.com
www.injectorrx.com/services.html
www.injector-rehab.com/
Fuel Injection
www.msefi.com
www.witchhunter.com
- T_Dub
06 Jun 2012 14:38 #527259
by T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
Personally I'd get new injectors anyhow, with a turbo you'll probably need more fuel.
AEM makes a nice little computer too for small vehicles, called the EMS-4. Bit more expensive than the Megasquirt, but its a really nice package.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- kz1000SF
06 Jun 2012 16:29 #527272
by kz1000SF
Sweet info, thanks guys! I don't plan on running high boost, i just had the top end rebuilt.
06 Jun 2012 17:35 #527278
What did you do to the top end ???
No big cams in a turbo.. Weld crank, Turbo pistons. The list of improvements will grow as the project proceeds weather you think that today or not. It just kinda happens
- kz1000SF
06 Jun 2012 17:47 #527279
by kz1000SF
I bought the bike for $300 but it was in pieces. The motor had the heads, came and barrels removed. I had ttp purchase several missing pieces. It has new gasgets, new cam chain tensioner and cams re-installed. That's what I meant. I will upgrade beds pistons in the futer but want to build a low psi setup that will work for awhile on stock.
- kz1000SF
06 Jun 2012 17:49 #527280
by kz1000SF
Stupid Droid auto correct! Cams*
