- Thank you received: 2
78 kz1000 won't go into 2nd gear??
- vintagebiker
04 Jun 2012 15:29 #526828
by vintagebiker
If all else fails, JUMP!
78 kz1000 won't go into 2nd gear?? was created by vintagebiker
I have just reassembled this 1978 KZ1000 a2a and have put the motor back into the frame and i am trying to make sure everything is shifting properly before i go any farther. It will slip into first and back to neutral but I can't get it into any highter gear. I am rotating the rear tire while I do this.
I hope I don't have to pull this motor out.
thx for any help
thx for any help
- wireman
- Thank you received: 299
04 Jun 2012 15:44 #526832
by wireman
Replied by wireman on topic 78 kz1000 won't go into 2nd gear??
You have to spin it pretty quickly
- munkybrain2010
- Clueless..
04 Jun 2012 22:05 #526917
by munkybrain2010
Keep it together man!
79 KZ650 "Geto Cycle"
Replied by munkybrain2010 on topic 78 kz1000 won't go into 2nd gear??
yout could tow it behind your buddys truck to see if it shifts haha
- bluej58
- Thank you received: 511
04 Jun 2012 22:23 #526925
by bluej58
78 KZ1000 A2A
Replied by bluej58 on topic 78 kz1000 won't go into 2nd gear??
If you haven't taken the gear cluster apart you are probably OK
You need the motor running to go through the gears.
JD
JD
78 KZ1000 A2A
The following user(s) said Thank You: vintagebiker
- baldy110
- Thank you received: 512
04 Jun 2012 22:25 #526927
by baldy110
Replied by baldy110 on topic 78 kz1000 won't go into 2nd gear??
The are three small ball bearings inside the tranny that will not allow it to shift into second from neutral unless your moving. The rear tire has to be moving fast enough to allow centrifigal force to spin these ball bearings out allowing the tranny to shift into second. It was Kawasaki's idea of making it easier to find neutral without overshooting into second gear.
- vintagebiker
04 Jun 2012 23:27 #526958
by vintagebiker
Replied by vintagebiker on topic 78 kz1000 won't go into 2nd gear??
I only ever saw that once in a tranny when i was school in 1981. That makes sense. Thank god. That motor is a B%&^$* to get in and out. I put it in with the cylinder head off. Much easier.
thx again what a relief.
