Can a chromed valve cover cause oil leaks?
- Kapahulu
03 Jun 2012 23:56 - 03 Jun 2012 23:58 #526693
by Kapahulu
2strokeworld.com
Can a chromed valve cover cause oil leaks? was created by Kapahulu
I've had oil leak issues with my '78 KZ1000 pretty much since I bought it last summer.
This thread helped and I thought I had the oil leaks beat. Then I took a 90 mile ride and the oil was weeping again. I thought it was the cam caps. Now I'm wondering if it's the cover. This cover has been chromed and I'm wondering if the chroming makes the surfaces more prone to letting oil get past the cam cover gasket?
Does anyone else here have experience with chromed valve covers on a KZ1000?
2strokeworld.com
Last edit: 03 Jun 2012 23:58 by Kapahulu.
- wireman
- Thank you received: 299
04 Jun 2012 00:00 #526696
by wireman
Replied by wireman on topic Can a chromed valve cover cause oil leaks?
Chrome makes the surface smooth,hard for gasket to seal against it.
If you replace valve cover gasket buy a thick one from z1 enterprises and spray it down with copper coat before installing it.
Of course if youre pulling valve cover off its a good time to have the valves checked/adjusted while youre in there.
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
04 Jun 2012 12:22 #526777
by andy9802gt
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Replied by andy9802gt on topic Can a chromed valve cover cause oil leaks?
My brother had to sand the chrome off the sealing surface of his.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- Kapahulu
04 Jun 2012 13:52 #526800
by Kapahulu
2strokeworld.com
Replied by Kapahulu on topic Can a chromed valve cover cause oil leaks?
I have an old KZ motor in the backyard and I took the cam cover off it last night. This week I'll change out the covers and hope to fix the problem.
2strokeworld.com
