cam tensioner noise
03 Jun 2012 17:01 - 03 Jun 2012 17:05 #526619 by jdbusch
cam tensioner noise was created by jdbusch
so i put an APE KT1100 on my 83 kz1100 and now its making a god awful clicking grinding slapping noise and idle. any ideas? ive tried loosening it tightening it and im lost.
possible hole in guide? bad chain? stupid installer?
sounds like the chain is grinding on the adjuster tip.
HELP
Current:
1983 KZ1100-A3 Shafty
Gone:
1979 KZ1000-E Shafty
Email:
jdbusch1978@hotmail.com
Last edit: 03 Jun 2012 17:05 by jdbusch.
03 Jun 2012 19:01 #526626 by APE Jay
Replied by APE Jay on topic cam tensioner noise
The adjuster tip never contacts the chain.
  • wireman
03 Jun 2012 19:36 #526633 by wireman
Replied by wireman on topic cam tensioner noise
Id say try reinstalling it B)
03 Jun 2012 23:41 #526686 by jdbusch
Replied by jdbusch on topic cam tensioner noise
i didnt think it did unless the guide was totally shot.
what else could be causing the noise?
wasnt not implying a bad tensioner just waht the noise sounded like
Current:
Gone:
Email:
03 Jun 2012 23:51 #526690 by Patton
Replied by Patton on topic cam tensioner noise
Is there a stock part missing or incorrectly installed?
Good Fortune! :)
  • wireman
04 Jun 2012 00:03 #526699 by wireman
Did you turn motor over by hand while tightening it?
Did you remember to have valve cover installed first?
04 Jun 2012 00:40 #526712 by jdbusch
yeah valve cover was on. and i turned engine over slowly while i tightened the tensioner to take out slop.
all i did was remove stock auto tensioner and bolt on the APE turned it in by hand until i felt a little tension. then turned engine over checked play, turned over checked play, and so on . once i felt no more play, i tightened the set nut and fired it up then heard the noise.
tried loosing it up a lil with no result so i tried small increments of tightening with no results but at 3000 rpm the noise is gone.
Current:
Gone:
Email:
  • wireman
04 Jun 2012 00:43 #526714 by wireman
Sometimes on a cold motor or one that has carbs out of synch you can here a little cam chain noise which is normal at lower rpms,not saying its definately the case here though.
does it go away after motor warms up a little? B)
04 Jun 2012 01:20 - 04 Jun 2012 01:22 #526724 by jdbusch
gets worse nd this is far beyond a little noise its alot
Current:
Gone:
Email:
Last edit: 04 Jun 2012 01:22 by jdbusch.
  • wireman
04 Jun 2012 02:20 #526730 by wireman
Did it make any noise with stock tensioner? B)
04 Jun 2012 07:03 #526739 by jdbusch
not near the noie now but the stock tensioner was siezed up
Current:
Gone:
Email:
  • wireman
04 Jun 2012 10:19 #526755 by wireman
time to reinstall :)
The following user(s) said Thank You: jdbusch
