- Thank you received: 3
cam tensioner noise
- jdbusch
03 Jun 2012 17:01 - 03 Jun 2012 17:05 #526619
by jdbusch
Current:
1983 KZ1100-A3 Shafty
Gone:
1979 KZ1000-E Shafty
Email:
jdbusch1978@hotmail.com
cam tensioner noise was created by jdbusch
so i put an APE KT1100 on my 83 kz1100 and now its making a god awful clicking grinding slapping noise and idle. any ideas? ive tried loosening it tightening it and im lost.
possible hole in guide? bad chain? stupid installer?
sounds like the chain is grinding on the adjuster tip.
HELP
HELP
Current:
Gone:
Email:
Last edit: 03 Jun 2012 17:05 by jdbusch.
- APE Jay
- Banned
- Thank you received: 58
03 Jun 2012 19:01 #526626
by APE Jay
Replied by APE Jay on topic cam tensioner noise
The adjuster tip never contacts the chain.
- wireman
- Thank you received: 299
03 Jun 2012 19:36 #526633
by wireman
Replied by wireman on topic cam tensioner noise
Id say try reinstalling it
- jdbusch
03 Jun 2012 23:41 #526686
by jdbusch
Current:
Gone:
Email:
Replied by jdbusch on topic cam tensioner noise
i didnt think it did unless the guide was totally shot.
what else could be causing the noise?
wasnt not implying a bad tensioner just waht the noise sounded like
Current:
Gone:
Email:
- Thank you received: 2098
03 Jun 2012 23:51 #526690
by Patton
Replied by Patton on topic cam tensioner noise
- wireman
04 Jun 2012 00:03 #526699
by wireman
Did you turn motor over by hand while tightening it?
Did you remember to have valve cover installed first?
- jdbusch
04 Jun 2012 00:40 #526712
by jdbusch
Current:
Gone:
Email:
yeah valve cover was on. and i turned engine over slowly while i tightened the tensioner to take out slop.
all i did was remove stock auto tensioner and bolt on the APE turned it in by hand until i felt a little tension. then turned engine over checked play, turned over checked play, and so on . once i felt no more play, i tightened the set nut and fired it up then heard the noise.
tried loosing it up a lil with no result so i tried small increments of tightening with no results but at 3000 rpm the noise is gone.
Current:
Gone:
Email:
- wireman
04 Jun 2012 00:43 #526714
by wireman
Sometimes on a cold motor or one that has carbs out of synch you can here a little cam chain noise which is normal at lower rpms,not saying its definately the case here though.
does it go away after motor warms up a little?
- jdbusch
04 Jun 2012 01:20 - 04 Jun 2012 01:22 #526724
by jdbusch
Current:
Gone:
Email:
gets worse nd this is far beyond a little noise its alot
Current:
Gone:
Email:
Last edit: 04 Jun 2012 01:22 by jdbusch.
- wireman
04 Jun 2012 02:20 #526730
by wireman
Did it make any noise with stock tensioner?
- jdbusch
04 Jun 2012 07:03 #526739
by jdbusch
Current:
Gone:
Email:
not near the noie now but the stock tensioner was siezed up
Current:
Gone:
Email:
- wireman
04 Jun 2012 10:19 #526755
by wireman
time to reinstall
The following user(s) said Thank You: jdbusch
