- Thank you received: 3
Drips of oil from stator cover?
- SeattleKZ
03 Jun 2012 11:44 - 03 Jun 2012 11:53 #526582
by SeattleKZ
Drips of oil from stator cover? was created by SeattleKZ
I noticed my bike drips a couple of drips from where the wires come out of the stator cover. The bike is a 1977 KZ1000.
Is it normal to have small amounts of oil in that area?
Is it the crank seal behind the stator/rotor?
What parts would I need to get to the fix the problem?
Thanks in advance.
Thanks in advance.
Last edit: 03 Jun 2012 11:53 by SeattleKZ.
- DoubleDub
- Visitor
03 Jun 2012 12:04 #526586
by DoubleDub
Replied by DoubleDub on topic Drips of oil from stator cover?
Welcome to the Z1/Kz900/Kz1000 most common leak (besides maybe the tach cable seal).
It is normal, but not from the factory. There is a wet stator on these bikes (oil in the stator cover) and over time the grommet the wire runs through gets hard and oil begins to seep out.
You will need the following to stop the leak:
Good luck!
- www.z1enterprises.com/Alternator-cover-r...Z900-KZ1000-373.aspx
- www.z1enterprises.com/Gasket--Alternator...-85-KZ1100-2650.aspx
- Wire cutters
- Shrink wrap
- Soldering iron
- JIS screw driver to remove cover
- Possibly some high temp silicone on the inside of the grommet (this is debatable and has been debated)
Good luck!
- SeattleKZ
03 Jun 2012 12:09 #526588
by SeattleKZ
Replied by SeattleKZ on topic Drips of oil from stator cover?
Short and to the point, perfect. Thanks.
- bluej58
- Thank you received: 511
03 Jun 2012 15:41 - 03 Jun 2012 15:43 #526606
by bluej58
78 KZ1000 A2A
Replied by bluej58 on topic Drips of oil from stator cover?
I bought the grommet but decided to try and seal it with Permatex first.
First I cleaned the grommet and wires real good with mineral spirits ( paint thinner ) followed by soap and water then I let it dry out real good before applying the silicone .
I also pushed the wires into the strator cavity as far as I could before cleaning them so that when I coated everything I could pull the wires with the goo into the grommet
You should still replace the gasket though.
1000 miles on it so far with no leaking and it was a mess before.
78 KZ1000 A2A
Last edit: 03 Jun 2012 15:43 by bluej58.
The following user(s) said Thank You: SeattleKZ
- SeattleKZ
03 Jun 2012 17:09 #526620
by SeattleKZ
Thanks, if I don't wanna cut the wires I'll try this.
