- Thank you received: 2
TK 22 Dyno jet instructions Suck !
- Gar1800
Attachment IMG_14251_2012-06-02.JPG not found
Thanks , Gar
- Thank you received: 2098
home.comcast.net/~loudgpz/GPZweb/TK22mainPage/TK22mainPage.html
- Gar1800
Gar
www.kzrider.com/filebase/doc_download/208-kzcarbneedleremove
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- The Gringo
Gar I'm attaching a diagram of the carb so you can see what I'm talking about it is #12 in the diagram #13 is the lockwasher you will be removing as well. If you have a screwdriver with a magnetic tip that is helpful especially when it comes time to reassemble.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Gar1800
Gar
- loudhvx
- Thank you received: 1616
Do not remove the nut and screw from the slide arm adjuster mechanism. That is sometimes difficult to get back together, and easy to lose parts. It does not have to come apart. You just need some skinny screwdrivers, blade type for removal, and small philips (JIS, actually) to re-install.
There are two small scres inside the slide that come out in a tricky manner.
Step one is remove the screw holding the arm to the throttle shaft.
The tricky part is removing the tiny screws inside the slide. One can be accessed while the slide is down, but the other can only be accessed while the slide is pulled upward.
After doing it several times it's easy and becomes second nature. It helps to have the exact right set of screwdrivers too.
I edited the diagram to show where there are two screws in case anyone else comes across this thread.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Gar1800
The next question which I still dont understand is the Dyno kit comes with # 98 mains and bigger. Its suggested by (loudhvx) that I use # 96 mains .. Am I suppose to drill out the stock mains to 96 like the pilots, or am I missing something here?
Gar
- Gar1800
Gar
- The Gringo
Gar1800 wrote: Thanks "The Gringo" thats what I was missing, haha I wonder how long it would have taken me to find those without your help. Thanks so much.
Gar
Glad to be of service.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- loudhvx
I get a lot of requests for jet info on KZ550's, and since I have a bad memory, I can't keep everyone's setup straight in my head, so I apologize in advance if you've already told me, but what exhaust do you have and are you running the airbox?
I realize swapping jets around is no easy task when the bike still has the airbox so I understand the desire to get it right the first time. But have we talked about you using the Dynojet kit and/or the 98 mains that come with it?
1981 KZ550 D1 gpz.
Other links.
