- Thank you received: 36
KZ650 clutch cover - is this a one-off?
- faffi
02 Jun 2012 11:12 #526434
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
KZ650 clutch cover - is this a one-off? was created by faffi
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- RonKZ650
- Thank you received: 240
02 Jun 2012 20:18 #526484
by RonKZ650
Replied by RonKZ650 on topic KZ650 clutch cover - is this a one-off?
i looked at all of mine and none have the ridge.
- Powerstroke_fan
- Thank you received: 83
03 Jun 2012 08:35 #526559
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic KZ650 clutch cover - is this a one-off?
Iam pretty sure that my old 650 had that same cover with that ridge.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- drfantastik
03 Jun 2012 10:30 #526569
by drfantastik
\'77 KZ650C
Harrisburg, PA
Replied by drfantastik on topic KZ650 clutch cover - is this a one-off?
my 77' 650 c1 has the same cover... I believe its original.
\'77 KZ650C
Harrisburg, PA
- gd4now
- Denco where did you go?
- Thank you received: 440
03 Jun 2012 10:57 #526572
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic KZ650 clutch cover - is this a one-off?
It is hard to tell from your picture, but my 77 B1 does not appear to have as pronounced a ridge as yours appears to have. Mine does have a very slight ridge, but from your picture it appears yours has a larger one.
1977 KZ650 B1
